Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing I would like step by step instructions on how to finalize a disk, Thanks
  • Anonymous Jan 15, 2008
    Finalizing problem
  • sylviagraves May 11, 2010
    I don't see the option to finalize when I go to edit disc. I finally figured it out with the manual last yr., but I forgot how I did it. And I can't find my manual.
    Problem Solver:
  • 5 Answers
All units are different but you'll insert the disc to be finalized,
go into your disc menu, edit disc and you should see a finalize disc.
The disc will finalize (this usually takes a few minutes).
You will no longer be able to record on this disc so make sure you are finished with it!
If the disc is not finalized, you will not be able to play it in any DVD player other than the one you recorded it in!
I know it's not step by step but I hope this helps :)
Posted on Jan 27, 2008
SOURCE:
Canon dc320 can't finalizing disk in video mode
You can download a copy of the instruction manual from here:-
http://www.canon.co.uk/Support/Consumer_Products/products/camcorders/Digital/DC_series/DC320.aspx?DLtcmuri=tcm:14-734954&page=1&type=download
You will have to agree the their licensing rules first.
Finalizing is featured on Page 45.
Apr 05, 2012 | Canon DC230 DVD Camcorder
Finalizing dvd on Magnavox zv450mw8a
You have to finalize after each recording and it is okay to use autofinalizing. Thanks.
Feb 11, 2009 | Philips Magnavox DVD/VCR Dual Player
FINALIZING DVD+R DUBBED FROM VHS TAPES
The manual gives you incorrect info.
To FINALIZE disk:
1. Press [HOME] button;
2. select [SETUP].
3. Scroll down to DVD ICON and SELECT
4. Select [FINALIZE]
Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
Dec 17, 2008 | Zenith XBR716
Panasonic DVD Recorder
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Pplease update this and we'll proceed to the next step.
Thanks,
Dan
Sep 07, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
FINALIZING ISSUE
Press FUNCTIONS button;  Select DISK INFORMATION; Select FINALIZE; YES; START; ENTER.
Jul 18, 2008 | Panasonic DMR-E50 DVD Recorder
VDR-D210
the disc is most probally badly manufactured this is why it could not finalize. the only thing you can do now is playback the disc in the camera and plug the AV out into a stand alone dvd recorder and dump it to disc or hdd.
Jun 08, 2008 | Panasonic VDR-D200 DVD Camcorder
Finalize
to finalize the disk for enabling discs to be  played on other devices. Connect this unit to the AC adaptor. Finalization cannot be executed using a battery. Rotate the mode dial to select the arrow. Press the MENU button, then select SETUP, FINALIZE, YES and press the joystick. Select whether or not to create a top menu, then press the joystick. When the confirmation message appears, select YES then press the joystick. hope this helps you. julie
May 19, 2008 | Panasonic VDR-D100 DVD Camcorder
Cant open/view DVD-R videos on my PC
there should be a button on the inside of the view finder. just push that and follow instructions?
Mar 24, 2008 | Hitachi DZ-MV550 DVD Camcorder
Canon dvd camcorder DC210
Ok, Guest @ solution #1 and #3 solved this for me.
Step 1. remove battery pack.
Step 2. Plug in to outlet.
Step 3. Insert desired disc.
Step 4. Toggle down on the "mode" lever for "Play-back" mode.
Step 5. Press "function"
Step 6. Scroll to and select "menu"
Step 7. Scroll to and select "disc options"
Step 8. Scroll to and select "Finalize"
Step 9. Scroll to and select "Yes"
Follow prompts from there.
This worked for me.
Thank you all!!!
Sep 23, 2007 | Canon DC210 DVD Camcorder
Finalizing vs. not finalizing a DVD-R. DVD-R vs. DVD-RAM?
on standard players. The write all the information that a standard player looks for to read the disk. Nothing is lost if you take the DVD out of the recorder without finalizing it. On a PC, you would tell the software to eject the disk. Later model hardware can usually reopen a disk after it has been finalized. Is this a typo? 'I know that the disc cannot be seen in a DVD player after being finalized'. It should read; I know that the disc can be seen in a DVD player after being finalized
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
456 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
