Question about Zhone (6218-I2-200) Router
How do i get the wep key from this router. I got mine from NorthState Communications.
  • Zhone Master
  • 32,281 Answers
A brand new wireless router will not have and encryption set.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Posted on Nov 13, 2009
How do i connect my nintendo dsi to the internet?
You need to enter into the settings, then click on wireless Communications search for your router and enter the wep key and you should be all set. You only have to enter the wep key once unless you delete it by mistake..
Sep 09, 2011 | Computers & Internet
Tip
How to set up WEP on Linksys Router
Setting-Up 152-Bit WEP Wireless Security on a Linksys Dual-Band A+G Wireless Router
Question
How do I set up 152-Bit WEP on a Linksys Dual-Band A+G Wireless Router?
Answer
Wired Equivalent Privacy (WEP) can be a 64-bit key with 10 hexadecimal digits, a 128-bit WEP key with 26 hexadecimal digits or a 152-bit WEP key with 32 hexadecimal digits. This encryption will prevent other users from connecting to a wireless network using your own WEP key. It will also protect your wireless transmissions/communications from being accessed or received by other users.
NOTE: Make sure to change the wireless settings of either Wireless-A or Wireless-G depending on the standard your network is using.
152-bit WEP key only applies to 5GHz 802.11a Wireless enabled network.
To setup WEP Wireless Security on your Linksys router follow the steps below.
Setting-Up the Linksys Router to use WEP
Step 1:
Access the router’s web-based setup page. For instructions, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless then click WirelessSecurity.
Step 3:
Look for SecurityMode and select WEP.
For Wireless-A Settings:
4439-001.pngFor Wireless-G Settings:
4439-003.pngNOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 4:
Look for the Encryption drop down menu and select 152 bits.
Step 5:
Look for Passphrase and type a wireless network password of your choice, then click Generate. In this example “MySecretKey” was used.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 16 characters.
Step 6:
When you click Generate, the result will be a string of random characters.
Step 7:
Look for TXKey and select any number to determine which key you’ll be using. In this example, we selected 1.
4439-005.pngStep 8:
Copy Key1 since 1 was selected under TX Key.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 9:
Click 4058-005.jpg.
© 2010 Cisco Systems, Inc. All rights reserved.
on Feb 26, 2010 | Computers & Internet
I am trying to install a wireless printer and need the wep key?
It should be on the router itself... Mine wep key is under the mac ID#
Feb 13, 2011 | Linksys Wireless-G Broadband Router
Create wireless security
1.Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the URL web address location.
2. When the following dialog box appears, enter the user name and password to login to the main configuration window, the default username and password is “admin”.
3.Setup wizard is provided as part of the web configuration utility. User can simply follow the step-by-step process to get the wireless Router configuration ready to run in 6 easy steps by clicking on` the “Wizard” button on the function menu. The following screen will appear. Please click “Next” to continue.
4.Set Wireless LAN connection
Click “Enable” to enable Wireless LAN. If user enables the Wireless LAN, type the SSID in the text box and select a communications channel. The SSID and channel must be the same as wireless devices attempting to connect to the WLAN Router.
(When in FCC domain, you could chose ch1~ch11; in ETSI domain, you could chose ch1~ch13)
4. Click on Security.
5.Security
This function enables user to set authentication type for secure wireless communications. Open System allows public access to the router via wireless communications. Shared Key requires the user to set a WEP key to exchange data with other wireless clients that have the same WEP key. This router also supports WPA, WPA2 and WPA-PSK, WPA2-PSK.
6.Set the Security key and save the settings.
7. The Wireless is secured now.
You can find more information in the User Guide.
Here is the link: refer page #26,27,33 to get all the info.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N2_Manual_Cam.pdf
Jun 23, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
I want to encrypt a wireless network with wep
Question
Answer
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
4439-005.pngStep 8:
Step 9:
Click 4058-005.jpg.
Feb 26, 2010 | Linksys Wireless-G WRT54G Router
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Wep connection invalid
Your DS system doesn't support WEP security ..
So better u can change the router to WPA-PSK(TKIP) or u can try with no security ..
Feb 01, 2009 | Nintendo DS Lite Console
How do I findmy wep key?
Hello ffoeg66off, My friend has the same make of router, If you can't find your wep key, are you sure it has one, not all routers have them, mine does, but my friend doesn't. If your Nintendo DS askes for a wep key like mine did, try to find a long conbination of letters and numbers, if it doesn't, you dont need one!
Dec 29, 2007 | NetGear WGT624 Wireless Router
Speedstream 6300 network key
Wireless security is commonly performed by encryption using wep setting a network key. That key is to be shared by both the router and the network card to allow encrypted communications. If appears you have not provided the network key that was configured into wireless router to the wireless adapter card to allow them to exchange encrypted communications. The preferable solution would be to get the active network from the router and provide in to the wireless adapter in the prompt / request you were presented. This will protect you wireless network from access by those you have not shared the key with.
Dec 24, 2007 | Siemens SpeedStream 6300 (33A6300001)...
Zhone (6218-I2-200) Router Logo
835 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
