Question about Makita BSS610 18V 6-1/2" LXT Lithium-ion Circular Saw Kit
I have makita bss610 battery operated circular saw that will not operate. Could the motor be burned out or should I look for other reasons? The motor turns freely and I do not see any visible evidence of burn marks. tjedlo
  • 460 Answers
Are the batteries charged are the brushes worn out. have it checked by a pro..
Posted on Nov 12, 2009
    Brigadier General:
  • 4,088 Answers
The usual problem with these types of units is the battery goes bad and won't accept charge anymore, or the charger itself is defective due to a broken power cord. Obtain a DC voltmeter and check the output voltage of the charger where it connects to the battery. It should measure several volts higher than the rated voltage of the battery. If this checks good, measure the voltage at the battery terminals which should be somewhat higher than the rated voltage. Problems in the motor can be the switch itself, or it may have a defective brush. Connect the meter to the wiring with the battery plugged in (if it is charged) and check for voltage at the motor with switch turned on. Remove each brush and check for length, burning, collapsed spring, or other damage. Occasionally, a wire can break within the field winding due to vibration. Hope some of this helps!
Can I use makita 5007nb circular saw on 220vAC.?
i assume it will overheat and burn up at 220 volts. its not made for that. make up an outlet with one hot and a neutral off the 220 line
Feb 17, 2018 | Makita Saws
My Makita DSS610 18v cordless circular saw stopped working mid cut. I changed the battery to another, fully charged, one but still nothing. Tried again next day, with both batteries, still nothing.
Hello Derek, it seems that your motor or motor brushes have failed please contact the manufacture about replacing the motor brushes.
Sep 15, 2016 | Makita Saws
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
Sparks coming from motor
Sounds like the motor has gone on this. Get it checked out but it might not be economical to be repaired. It could cost at least 50.00 for the parts alone.
Nov 14, 2012 | Makita 5704Rk 7"/190Mm Circular Saw 240V...
How to get motor out of houseing on a makita 5007MG circular saw
The armature and field will need to come out. It's quite a bit of work to swap everything over. Here is a parts diagram which should help.
Makita 5007MG diagram
Aug 06, 2012 | Makita 5007MG Factory Reconditioned 7 14...
Makita Saw Bss610 stopped
It might be that the brushes have got stuck in the brush holders. Take them out and make sure they run free.
Jun 17, 2012 | Makita Saws
Makita BSS610 18V 6-1/2" LXT Lithium-ion Circular Saw Kit Logo
228 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
