Question about InFocus LP 70 Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
LP70 powers itself down after 30 seconds or so. It well display fine during that time, but then shuts down. Happend all of a sudden. Help.
  • 72 Answers
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Posted on Nov 12, 2009
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
InFocus LP70 keeps shutting off
if the fans go off imediately too, it's the power supply. if the fans stay on, it's either the lamop, ballast, or colorwheel. either way, you may need to send it in to an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 14, 2009 | InFocus LP70+ Multimedia Projector
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 color problem
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
May 11, 2009 | InFocus LP70+ Multimedia Projector
Cannot see computer displyed on output of infocus screen shot
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the
projector checks first for active video during power-up. Highlight
Default Source and click the left or right mouse button to toggle
among the options.
Jan 12, 2009 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
Infocus LP70
its not geting power lust like mine
Dec 11, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP 70 Multimedia Projector Logo
774 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
