Question about Maytag MED9700S Electric Dryer
Need to open to clean lint out - Maytag MED9700S Electric Dryer
  • 464 Answers
Perhaps the attached breakdown will help you to see how the cabinet comes apart.need to open to clean lint out - 250
Posted on Nov 13, 2009
Dryer heats but clothes wont dry and have checked lint screens front and back. How much "air flow" should be coming out the back of the dryer?
Do not use this dryer until you fix it. You need to check the pipe or flexible tube that comes out of your dryer (where the hot air comes out). Even though you clean your dryer lint trap some lint gets by. If you can get to it, go outside and find the opening where the dryer air comes out of your house. Then open the little door and look inside but not when the dryer is running. If there is any lint inside clean it out. Then disconnect the air outlet from the back of the dryer and inspect. It should be free of lint. If it is full of lint clean it all out. You can also call a pro to perform the inspection and cleaning. Good luck.
Jan 16, 2014 | Dryers
LENT SCREEN SEEMS TO LET LINT BY IT LINT IS BLOWING OT THE BACK
Maybe you need to do a cleaning. open the dryer up and clean out the lint. Use this GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How do u know if the heating coil is bad?
If you are feeling any heat at all when you place your hand by the air vent in the back, your element is at least partially working. We must determine if your model has a single or double element. If you have a double, perhaps only one side is working. To determine this, I will need the model number located under the lid or on the back of the unit.
If you have NO hot or warm air, it may be your element or the thermal fuse. Need model number.
But before we do that...
The most common cause of this is just a simple build up of lint. No matter how well you clean the lint filter during use, lint does build up and may require cleaning every few years or so. If you do have some warm or hot air and it seems to take two cycles to dry your clothes, try these simple checks (unplug dryer):
1. Insure that your vent hose is not clogged with lint. Unhook it on both ends and see if you can see through it. If there is a blockage, remove lint, reconnect and you should be fine. 2. Insure that the flaps on the vent outside of your house are free of lint and can open and close freely. If they are upstructed, clean. If they do not open or are bent, you may need to replace the vent. 3. Pull out your lint screen and see what you see? Lint build up? Take a coat hanger and bend it to stick into the lint trap well. Can you pull out any lint? Pull out as much as you can. Also look into the vent on the back...is there lint inside? Use your hanger. This may involve opening the top of the unit, or pulling off the front to clean. But let's get the model number before you get that far.
Write me back with model number or let me know if cleaning the hose and/or vent help. I look forward to assisting you.
Aug 02, 2010 | Kenmore Dryers
Lint screen holder is full of lint
Yes, clean it out immediately. The lint screen should pull right out with no screws holding it. It should be cleaned every other load!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Magic Chef CYE4000AWW Electric Dryer
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Mar 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I opened dryer and found burned lint. There was about a half inch of material around the heating elements that had also started to burn.
clean the lint out and make sure the coil is undamaged. dryers need to be taken apart and lint cleaned out once in a while. also clean the exhaust line out real good as too much lint can increase the back pressure, not letting all the lint out of the unit.
Apr 28, 2008 | Dryers
Maytag MED9700S Electric Dryer Logo
81 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
