Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Food is not cooking evenly, oven is only 1 years
Food is not cooking evenly in the oven, rang is only 1 years old.
  • 1 more comment
  • lika390 Nov 12, 2009
    I just did and they told me that my warranty expired last month...
  • lika390 Nov 13, 2009
    It is Kenmore Dual Fuel Range: top is gas, oven is electric.
  • 460 Answers
See if still under warranty and call a serviceman..
Posted on Nov 12, 2009
  • 1 more comment
  • john regrut Nov 12, 2009
    you should have bought an extended warr. it will cost you a service call to find out that there is probably nothing wrong with your stove. question,,,, is it gas or electric? get back to me.
  • john regrut Nov 13, 2009
    my suggestion to you is to have the bottom heating element replaced.. there is a weak spot in that element, not heating properly...good luck and a goodday..
    you need to replace the bottom element..
The fan oven gets hot but food cooks more on one side than the other. Food needs to be turned for even cooking. Food also takes much longer to cook than stated on packaging.
packaging cooking times is only a guide... not exact
must be an electric range if it slow cooking
thats why professional cooks prefer gas
May 31, 2016 | Kitchen Ranges
I have a Kenmore Elite Double Oven Range Model 790.9750. It's just 2 years old. It has been burning food only in the middle of the left side of the upper oven. Nothing cooks correctly because that
Check your door seal by doing a paper-pull test. If the paper pulls out easily on one side and not the other, then you found your problem. You might be able to "tweak" the door, but be careful - if you twist the door too much, you could break the glass. The other (and safer) solution is to replace the door seal. Another thing that could cause uneaven heating would be an element that has a "hot spot", but this is rare. Finally, if the insulation of the oven cavity was done improperly at the factory, that could also cuase uneven heating, but this is even rarer than an element with a hot spot. In all my 9 years of servicing ranges, I only encounter this cause 1 time. Ussually it's a damaged or compressed door seal.
Dec 23, 2014 | Kenmore Kitchen Ranges
Why did my whirlpool microwave display quit, everything else works. less than 2 years old
Over the range ovens of all brands are prone to failure of the electronics due to heat and steam from the food that's cooked on the range below them. It's not extremely common, but you do see more of these types of failures on these as opposed to counter top models.
Apr 26, 2014 | Microwave Ovens
Oven not cooking at correct temperature & loses heat
Had a similar issue - but my unit is eight years old. Turns out my issues were my oven ignitors were failing and one of the burners had corroded causing the flame to only light on one side. To fix I replaced two ignitors (apparently they are to be replaced every 3-5 years) and cleaned the burner with a brass wire brush. If you are handy the ignitors are easy to replace - one screw and two wires each. Burner was one screw to remove.
Ceramic ignitors if wearing out can cause delayed lighting of the oven burners and/or reduce the gas flow - hence not heating up.
That was my experience ....
Jan 11, 2010 | Viking VGSC366-6B Gas Kitchen Range
I just moved into a house and the GE oven appears to be approx. 16 years old. The oven will not cook between 300 and 450 degrees. It will either undercook or burn the food.
16 Years old? Sounds like you need to buy a new one. One thing you don't want to do now is to start putting lots of money into an old appliance.
Oct 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bosh over-the-range microwave. model HMV9305. Lights work, control panel works. Everything seems normal but the food does not cook. We checked set up. Everything seems fine. We use a marshmellow to...
its your magnatron tube, that is what makes the microwaves. the part # 492603, you can order it at marcone.com it should cost $100-150, if the micro is more than 6 years old I might not fix it.
Jul 21, 2009 | Microwave Ovens
Oven does not cook food fully.
I researched the Repair Clinic.com site and for the unit in question it drove me to the Bake Ignitor Glow Bar as being the problem. It is 90% sure the problem lays in this part and instructs to R&R the part.
Nov 22, 2008 | Maytag MGR5770 Gas Kitchen Range
Broiler element sparked fire, is the oven safe to use?
any food with an oil base will catch fire on a heating element, it will be fine to use but try to keep food from spilling out towards any heat source, use a try to collect any food drippings or a tray with vents if doing potatoes this will minimize any food dripping on the elements. it will smell for a while on the first cook as the oil will still be present on the element but it will soon burn off.
Jul 03, 2017 | KitchenAid KERC700LBS Electric Kitchen...
GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
226 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
