Question about Microsoft Office SharePoint Server 2007 Enterprise Full Version Volume License for PC
In a powewr point presentation, my laptop screen goes black when a connect the vga cable to the projector
  • 241 Answers
That's normal. If you want to see the PPT on both screens, press the "fn" key and another key that has either two little monitor icons or "CRT/LCD" on it. Each time you press the keys (at the same time), the output will cycle thru laptop LCD only, projector only, both, etc.
Some systems require you to have the projector attached and running to auto detect. Some don't. But all allow for the "fn" and LCD key adjustment.
Posted on Nov 12, 2009
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
How can i display a portable swivel projector from my laptop using a vga connection? Once im connected all i see is a color bar screen on the wall, do i press something to enable the picture?
There are different types of video outputs which your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Aug 30, 2010 | Toshiba Satellite A135-S4527 Notebook
I can not connect laptop with projector
Instructions
Things You'll Need:
Laptop computer equipped with a VGA, S-Video or HDMI output.
Overhead projector with the applicable input.
VGA, S-Video or HDMI cable.
Software to ready your content for presentation at the correct screen resolution.
DVI-VGA adapter, if you are using a Mac.
Step 1
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Step 2
Step 3
Step 4
Step 5
Step 6
Connecting a laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Step 7
Hope this helps
Aug 01, 2010 | Acer PD100 Multimedia Projector
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
We need to know how to hook the projector up to the laptop to project a power point presentation
You will need a VGA cable that can connect the projector to the laptop. This is usually the same cable that connects a monitor to a desktop computer.
Once you have the two connected, you will have to tell the laptop to send the video signal down the cable. This is normally done by pressing the FN (function) key on the bottom row of the keyboard, and the F8 key on the top. It will normally cycle through the following modes: laptop only (default), external, laptop and external.
Hope this helps and good luck.
Jan 15, 2010 | InFocus Proxima UltraLight S520 Multimedia...
When I plu-in the VGA cable my screen goes blank on my HP-1170. I then have to reboot to fix video on laptop. Done all the resolutions and I cant seem to get the external projector to show anything other...
reset the settings to factory default through the menu. swap out the cable. depending on your laptop, press function-f4 or function-f7. if still nothing, you may have a main board issue.
Dec 27, 2009 | 3M MPro110 Micro Professional Digital...
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
Need to connect my dell laptop to a large screen projector using a computer video interface for vga and compatible computers I have a delllatitude d610 the interface is an inline2080
I assume you know how to connect the VGA cable and which function key is used to activate the second display. You will have problems if the laptop display size is not supported by the projector. Many older projectors will not work with wide screen laptops.
when you connect the projector, Just press the presentation mode on your keyboard, Fn + (Presentation Key), Sometimes F5 or F8!
Then you will see your desktop on the projector screen.hope this helps
Aug 13, 2009 | Dell Computers & Internet
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Microsoft Office SharePoint Server 2007 Enterprise Full Version  Volume License for PC  Logo
142 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
