Question about Philips Televison & Video
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix it and I think that I really messed it up. I took the back off of the TV and found a box with 6 screws. They were labeled Red Green and Blue. The top screw is for the intensity and the bottom screw is to focus. I tried turning up the blue and green intensity screws and there was a little pop and the bulbs turned off. I turned the power off on the front and then there was still only an orange picture, but it was just wavy orange lines when I turned it back on. Can someone tell me exactly what I broke and what I need to do to repair it? I think I might of burned out a bulb('s), but I don't really know.
    Problem Solver:
  • 9 Answers
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Posted on Feb 25, 2010
Philips model #50P8341A Picture is clear but orange.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2011 | Philips 50P8341 50" Rear Projection...
My Philips model 50p8341a 50" rear projection tv turns on, has sound but has no picture. Any ideas? Heard something about a convergence chip? Please advise.
you need ssb board is bad and you can,t git that part you can send to pts to have it rebuld. yes the stk 392-120 can drag the pix down but if you open it up you see a fouc blook go to the screen red or green or blue
turn it up just a litte the pix will come back. this is a know fact about this with this set i see a lot in my days of sevice ,at quaker tv
Dec 07, 2009 | Philips 50P8341 50" Rear Projection...
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Phillips 51pw936317f picture not as sharp as when new
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 17, 2009 | Philips 51PW9363 51" Rear Projection...
Philips 50P8341A MSRP from 2004
well it looks like the MSRP is $1600 for that model , but there is no record with phillips?
Nov 06, 2008 | Philips 50P8341 50" Rear Projection...
Black Picture
The picture coming on then going off to a totally black screen is a sign of the high voltage generator being marginal in its performance.
The repair may be simple and inexpensive; or something more sinister. The technician will have to tell you.
Let me know the outcome. I am very interested in this rather strange case.
Jan 14, 2008 | Philips 50P8341 50" Rear Projection...
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
