Question about Maytag Dryers
I have a rubbing noise noise when dryer is on on my Maytag PYG 2300 AWW
Unplug dryer and turn off gas. Lift the hinged top of dryer up and prop back far enough on wall so it will stay back. There are some tabs located just under the front of the lid that pop up easily. If not use a flat blade screwdriver and push in gently on tabs to release. Use a flashlight to locate tabs. Un-clip door switch from inside of front panel and set to side. No need to remove the wires from the switch. Remove screws (one on each side) at top front corners of unit that hold the front panel on. Remove front panel and set aside. Get a second set of hands and remove drum by pulling forward and lifting slightly while the second person slides belt off the back of drum. At this point all your components and parts are exposed. My problem ended up being a simple one and I fixed it without cost. There are two rear support pulleys that the drum rides on located at the back of the dryer cabinet. They are white pulleys with black rubber treads. These should spin freely and one of mine was not spinning and causing the dryer to squeal and moan terribly when running. In my opinion it is a design flaw and here is why. Upon closer examination I found that the rubber on the pulley that wears over time got down between the pulley bushing and the spindle it rides on and melted. This caused the pulley to sieze up. It melted due to being located directly above the heating unit. The fix: Remove pulley which is held in place with a snap ring, clean spindle and inside of bushing with denatured alcohol, and reassemble in reverse of dissasembly. Tip: Remove and clean both pulley assemblies while you have the dryer apart. Mine not only had melted rubber on the one above the heating unit but also I found a fair amount of hair around both spindles. I used a bit of graphite on the spindles before reinstalling the pulleys. Also as soon as I removed the drum I found LOTS of lint, hair, and other stuff in the bottom of the cabinet. Get a shop vac or use your home vaccum with and attachment and clean all this out to lessen fire hazard and increase dryer life.**** Make sure your unit is unplugged before doing this.****
Posted on Nov 13, 2009
Testimonial: "Perfect fix..Thanks"
MAytag 2300 aww does not heat
If this is a gas dryer it may be the ignitor has failed. There should be a panel you can remove to inspect the burner compartment. Turn on the dryer and look for an orange glow if you don't see any glow the ignitor is probably faulty and should be replaced. If it is an electric dryer it may be a bad heating element. Hope this helps.
Jan 03, 2014 | Maytag Dryers
Hi, My Maytag Atlantis MDE7400AYW is making a noise. It is the front of the drum ribbing on the front of the laundry opening. I pull back on it a bit and the rubbing noise stops. I ran it with the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer model MDET236AYW drum rubs against blower = loud squealing. drum slides forward and back about 1/4 to 1/2 inch. when slid back, it rubs against blower. when slid forward, does not rub. how can...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 21, 2011 | Maytag Dryers
Maytag neptune Model # mdg5500 AWW when i push
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud Rubbing noise from my Maytag Performa Dryer
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 20, 2010 | Maytag Dryers
The dryer is getting a black soot buidup in dryer that is turning white clothes gray
There are a few things to check here..
Note that from what your describing you dryer should be running hotter than normal also and the burner most likely is being shut off by the high limit thermostat vs the cycle thermostat.
1. Seening soot of any form is a sign that there is an incomplete combustion of the gas. This usually is caused by an air blockage or restriction. Check the following places:
a. The lint filter and the entire area where the lint filter fits.
b. The dryer vent to the wall can be kinked or blocked.
c. The outside flapper vent can have a build up of lint in it that needs cleared.
I think you will find a blockage some where. Just make sure not to use anything sharp when cleaning it out. And a Vacuum crevice tool works great.
If none of the above work repost here and we can go from there.
Dec 29, 2009 | Maytag PYG2300A Gas Dryer
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Excess water in clothes at end of spin cycle
SOUNDS LIKE THE MOTOR COUPLING TO ME.
May 15, 2009 | Maytag Washing Machines
Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Apr 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not starting
Sounds like a bad motor. A DIY job of about 3 hours and $125.00 for a new motor.
Dryers are pretty easy to work on if you have some tech ability and some common sense.
Mar 29, 2009 | Maytag Dryers
Dryers Logo
121 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
