Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My Kenmore XL Gas Burner will not light. The
My Kenmore XL Gas Burner will not light. The ignitor is sparking, but the gas won't light. Something (don't know) was spilled on top of the burner. I have scrubbed it and tried to make sure the vent holes are clear. At one point, the gas was pooling around the base of the burner on fire (scary). It has stopped pooling. You can smell gas, but nothing lights. When I flipped the burner around, the burner would not light on the opposite side either.
  • 22 Answers
Look at the pressure regulator
Posted on Nov 14, 2009
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Front right burner will not ignite
I'd get a briquette lighter down in there when you turn it on and try to light it manually. If it does not light, it is a gas supply problem (bad valve or control), and time to call appliance guy. If it does light, the spark path over to the burner may just be plugged with something. If you have gas + spark, but no fire, it almost has to be that the spark can't reach the gas for some reason. That usually comes from something being plugged up.
Nov 27, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
Kenmore 800 grill replaced ignitor i get a spark but it won't light
First and foremost, make sure the gas tank valve is turned ON and that there is adequate gas in the tank. If that all checks out, do the following:
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion,
slow).
4. Once the valve is full open, light the burner farthest from the tank first and turn it to HIGH. Did the
burner light and does the flame height look correct? If so, light the remaining burner(s) the same
way. Did all the burners light and the flame heights look normal. I so, you just solved the
problem (with a little help).
Remember to always turn the tank valve ON Very, Very Slowly.
If it didn't solve the problem, you will need to replace the grill's Regulator/Hose Assembly. You can purchase on at any home center or hardware store that sell gas grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 18, 2011 | Kenmore 800 sq. in. Cooking Area Gas Grill...
I have a kenmore gas grill that has the side burner. Up until recently, it has been working great. However, now the main grill won't light when pressing the ignition button but the side burner lights...
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Apr 09, 2011 | Kenmore 700 sq. in. Cooking Area Gas Grill...
My kenmore gas dryer wont heat....could it be the ignitor
if you do not hear a clicking noise with in 29 seconds upon starting it the ignitor is bad. the ckicking is the ignitor snapping a spark to the burner to light it up
Feb 24, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
After cleaning a burner we can light it, but the auto igniter doesn't work
Im assuming you are talking about an top burner. If so you may have gotten some cleaner or other obstruction in the burner gas flow route. This will cause the gas not to be able to rout in the direction needed for proper lighting. Also check and make sure there isnt a problem with spark ignitor.
Oct 27, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Dec 10, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
