Push power button green light flashes backlighting comes on for a second
  • landryele917 Nov 13, 2009
    26mf231d/37 lcd
  • landryele917 Nov 16, 2009
    Thank u fo4r the 411
  • 10,594 Answers
Let me know model number and brand of TV to provide you helpful info to solve its problem.
Post back as comments.
Thanks.
Posted on Nov 12, 2009
  • Shahid Electronics
    Shahid Electronics Nov 13, 2009
    26mf231d/37 lcd
    OK, either power supply has leaky capacitors problem that does not provide proper volts to boot up TV or back light inverter board sounds bad that sends error signal to system control chip to shut down TV.
    Please check power supply board for bulged/ leaky electrolytic capacitors and replace them with same ratings. If all capacitors found good/ no leaky then swap back light inverter board.
    Thanks.
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Aquos lc40le821e. LED is blinking constantly at a rate of 1 blink / 2 secs. Cant get the tv on. Any ideas? Thanks.
Sharp LCD tv tend to have trouble with power LED light and OPC light flashes together?That what u having?Yes,this tv is having trouble with it tv Tuner signal board itself.This tv is still useable.By pushing the power button again and wait for awhile than the backlight will come on and work,Sometime Power and OPC LED lights flashes quit awhile.Just have to push power button and wait have to do this 3 or 4 times,before tv backlight to come to work.I have a Sharp Aquo my self 46' do this most of the times.
Jan 01, 2011 | Sharp Televison & Video
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Techwood plasma twp 4210 broke
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Dec 07, 2009 | Televison & Video
Screen is black, green light is on. Disk light comes on for a second when power button is pushed, and fan comes on briefly. Otherwise, nothing. Same outcome on AC or Battery or Both. I tried the remove-AC,...
There are approx 6 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 3680 Laptop
I push the power button, the Green light comes on for a second
You have the yellow light of death you need to send it in to sony.
Good Luck and Please Rate
Mar 13, 2009 | Sony PlayStation® 3 (80GB) Console
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
