Question about Mitsubishi VS-45607 45" Rear Projection Television
POWER WILL NOT STAY ON - Mitsubishi VS-45607 45" Rear Projection Television
  • Mitsubishi Master
  • 5,568 Answers
Not an uncommon warning sign of a failing main power supply.
Listen at the rear of the unit for the (quiet) sound of a fan. If you don't hear one, the supply may just be shutting down from heat. If you do hear a fan, read the tip I paste below if you want to proceed with some troubleshooting. -------- Since you do have both audio and video briefly, this indicates that the more complex section of your set is working.
The assembly that most affects these two equally is the power supply and this is a common failure in all too many of more recently built TVs.
The supply is normally built on a separate board since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Posted on Nov 12, 2009
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
Nov 14, 2015 | Symphonic ST420FF 20" TV
What to do to fix my tablet that won't stay on after releasing the power button
If it doesn't stay on , you may have a broken battery . If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Insignia tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Insigina Repair Services.
Nov 12, 2014 | Insignia - Flex 8 inch Tablet with 8GB...
Power steering stiff after recon steering turns pump works steering stay stiff and hard no power steering even if you start the engine
Check the drive belt to the power steering pump and the level of fluid in the power steering reservoir.
Feb 18, 2014 | 1996 Honda Prelude
My phone will not stay on it turns on and it goes off... it will not stay on and go to home page> HELP!!!!!
If it does this while plugged in, I would factory reset the device. iPhones you reset while connected to a computer with iTunes. Android you usually power off the device, tap the power button then immediately press and hold (power + vol up) or (power + vol down) until you get a menu. Use the vol buttons to navigate and the power button to select the factory reset option.
Nov 24, 2013 | Cell Phones
Will not stay on
Have you tried plugging it into a different power point in your house?
If that doesn't make it stay on it is most likely a power supply issue with the receiver. More often than not it is cheaper to replace a receiver with a broken power supply than to pay someone to fix it.
Jun 17, 2010 | Marantz SR7500
Power button will NOT stay in / ON
please check with cord connected to computer
Mar 25, 2009 | Audio Players & Recorders
Won't stay powered on.
Did you use rechargeable NiMH battery try this. One's again its make same problem means. Check weather their is an DC plugin if it their means just buy the adapter regarding to it power supply...
Feb 18, 2008 | JVC XA-A55CL (256 MB) MP3 Player
Just got Verizon 755p - can the power stay on while charging?
Try StOIC (Stay On In Cradle):
http://mytreo.net/downloads/stoic-stay-on-in-cradle,221.html
It's free and it works - the screen will stay on whenever the Treo is connected to charging power (e.g., in the cradle).
Enjoy!
- IntelelctArsenal
Jan 18, 2008 | Palm Treo 755p Smartphone
Mitsubishi VS-45607 45" Rear Projection Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
