Question about Genius SW-5.1 1000 Computer Speakers
Genius SW-5.1 computer speakers, only 2 speakers, work!
Hello, i have Genius SW-5.1 computer speakers, and i have a strange problem.
I have tried almost every config on my sound board, but, only the front right, subwoofer, and back right speakers are only working when i connect them all togheter on the subwoofer. Is it a factory error or i have did something wrong? Please help me solve it!
I have the same problem.. i have tried everything... if you find the sollution i would appriciate if you shared your secret with me :)
Posted on Dec 29, 2009
I have the same problem and it is because my pc only have one plug for the speaker and it needs 3 so i did some research and i found this on amazon.com it seams that 17% of the customers buy it with the speakers it's Logitech 5.1 Game Console Adapter Convert Rca Plugs To A Single 1/8 and its only $4.99 so this is it :)
Posted on Apr 25, 2010
I have the Genius SW-V2.1 1250 speakers and they have been working fine until I used them on my laptop and tried to plug back into the desktop computer. I can't seem to find out where to plug everything in...
The output jack is usually labeled with a small diagram of a headphone or in case if its color coded then it will be green this is where you neeed to connect your speakers. Also if your desktop have a builtin speakers or any other output such as HDMI There is a possiability that when you unplugged your speaker it has chaged. Navigate to control panel and audio and select the appropriate output device.
Sep 26, 2013 | Genius SW-V2.1 1250 Computer Speakers
Lost installation cd
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
if these dont help
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
or you might download slimdrivers
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
hope it helps
Apr 02, 2012 | Genius SW-5.1 1500 Computer Speakers
My speakers sometimes work, and often not
It's a bad connection or bad speakers. Check your wires
Dec 11, 2011 | Genius SPF120 2 Speakers
I have a sistem genius 5.1...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 01, 2011 | Genius Soundmaker Value 5.1
I have a genius SW-HF5.1 5050 audio system.. everything is working when i test it. but when i play any music or movie the subwoofer is not working. The sub is working when i make the speaker test..
Conected via. 6x cinch? Most of audio signals actualy are not 5.1 - so that is IMAO why your sub is not working. Try search your audiodevice control for something like LFE. Or try playing DVD which has 5.1 audio (check player settings).
Nov 24, 2010 | Genius SW-HF5.1 5000 Computer Speakers
Driver for sw-j2.1 330
Speakers don't normally need drivers, have you plugged them into the speaker jack at the back of your computer (the green jack)
Sep 24, 2010 | Genius SWJ21 330W 2 Speakers
Woffer Problem GENIUS SW-HF 5.1 5005
Don't do anything to your speaker, it may ruin the warranty for it. The best thing to do is take your new speaker back to the store where you had just bought it. They may replace the speaker if found a factory defect on it. Contact first the store where you bought it.
I hope this could help you..:-) Thanks..
Dec 26, 2009 | Genius SW-HF5.1 5000 Computer Speakers
Drum in the subw.
The speaker amp has failed, best course is to just replace the system.
May 19, 2017 | Genius SW-HF5.1 5000 Computer Speakers
Genuis SP-G06 not working as no sound. Don't have driver discs, can't find driver download on net. Any help please??
The problem may not be with de speakers. They don't need drivers, try reinstalling you'r sound card driver... If that doese'n work, it means the speakers may be broken... But try the sound card thing firs...
Good luck,
Dan
Jan 19, 2008 | Genius SP-G06 Computer Speakers
Genius SW-5.1 1000 Computer Speakers Logo
997 people viewed this question
Top Genius Audio Players & Recorders Experts
ptpumpman
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Genius Audio Player and Recorder Expert? Answer questions, earn points and help others
