Question about RCA Scenium D40W20 40" Rear Projection HDTV
Heard a pop like a bulb blowing and can only get the sound. it makes a crackling noise when we turn it on.
  • Don
    Don May 11, 2010
    The most common failure on these sets was the high volatge splitter and then some cases the high voltage transformer. The part numbers will depend on your full model number. There is a label on the back with the full service number which will be your model number plus a few extra numbers such as D40W20BYX1 etc...
  • 668 Answers
It could have a arcing Hv Block or a something arcing on the Deflection Board. If the crackling noise is louder in the rear of the set, the Deflection Board is probably the cause. You can usually confirm by removing the lower back cabinet and observing the board on the left side. If you see any arcing at all, the board needs replacing. You can call Encompass Elect. for ordering the board at 1800-638-3328.
I hope this helps,
Skyassoc
Posted on Nov 12, 2009
  • 460 Answers
This set is ready for the bone yard.. tube coolant leaked onto the neck of 1 of the tubes. most likely green.. the rca scenium series was famous for this happening.. it will cost you close to or more than a thousand bones to repair this relic. go to costco or sams club and get a good brand name lcd flat panel tv. it wont last as long but are cheaper to get fixed....
I have a Mazda 6 5sp Manual, Crackling/Popping when stopped.
Could be something jumping around in the exhaust. Is your catalytic conv in that area?
Feb 19, 2010 | 2007 Mazda MAZDA6
I had just turned on the tv and heard a pop and the screen was blank. When I turn it on, I hear a crackling sound but no tv
If it is a LCD projection, like WEGA, sounds like a bulb replacement time. Look in your owners manual.
Feb 15, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My son got behing our tv and seems to have got some liquid in the back of it. We heard a pop and then the circuits blew. We tried to turn the tv back on and heard some crackling noises so we turned it off...
hello if the liquid has soak in to the transfomer it could have damaged it get a hairdryer give it a good going over make sure the powers off take the back off good luck
shaun
Nov 06, 2009 | Hitachi C57WD7000 TV
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
RCA Scenium D40W20 40" Rear Projection HDTV Logo
194 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
