Question about Samsung SCX 4521F All-In-One Laser Printer
Hama usb pr.converter 49284/sr-vista scx-4521fprinter
Where can i get this from 00017662 hama sim editor usb vista driver when i run i get message cannot load DLL
Hi try downloading the dll in question from here:
http://www.dll-files.com/
Copy it in the folder where the exe is located. It should work.
Mar 03, 2011 | Microsoft Windows Vista Home Premium...
I lost the installation disc for Samsung SCX 4521F and I would like to scan documents to my laptop (windows vista). 1) Where to find drivers for free downloading ? 2) How to convert the scanned+dowloaded...
DOWNLOAD YOUR DRIVER AT
http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4521F/XSS/index.idx?pagetype=prd_detail&tab=support
GOOD DAY
BOBUS
Feb 04, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I want ti install pc camra
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/HAMA/HAMA-Globe-300K-PC-Webcam-Driver-10-for-2000-XP-Vista.shtml
Jan 01, 2011 | PC Concepts 300K Webcam
Not charging video will not eject
CANON MV630I battery Specs:
  • Cell Type : LI-ION
  • Volts : 7.4V(Compatible with 7.2V)
  • Capacity : 4400mAh
  • Average Run Time :2-4 hours(minimum)
  • Color : GREY
  • Dimension : 55.10x38.20x39.90mm
  • Net Weight : 146.00g
  • Cpmpatible Model:
  • canon 5797a007, canon 5797a010, canon bp-508, canon bp-511, canon bp-511a, canon bp-514, canon bp-522, canon bp-535, canon pc511, canon vcn009, canon vcn009s, cta db-bp522, delkin dd/bp522, duracell drc522, empire bli-193-2.4, energizer er-c600, gp vcl008, hahnel hl-522, hama 46810, hama cp-810, optex li36, polaroid pr-522l, rayovac rv5462, sakar bp-522cl, sunpak hl-522s, techcell l522us, vivanco bp-22672decf09.jpg
    Jul 22, 2010 | Canon MV630i Mini DV Digital Camcorder
    Hama Wireless USB Adapter ''limited connectivity.''
    you need to modify the wireless settings on your router. In case, if WPA-PSK security is enabled change it to WEP 64 bit encrytion and than try.
    Feb 17, 2010 | Computers & Internet
    Not seeing the DVD rom after installing hama webcam suit
    Check their website for an updated driver for the webcam.
    Apr 03, 2009 | Dell Inspiron 1525 Notebook
    How can i find driver for my PC cam HAMA Metal pro? Thanks in advance.
    Hi!
    Click here:
    00062828 / PC-Webcam "Metal Pro" Thats the drivers for WIN 98SE/ME/2000/XP/VISTA Good luck Nic
    Apr 01, 2009 | Computers & Internet
    Problem scanning with samsung scx 4521f
    Sorry to have missed your initial posting...
    In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
    If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
    If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
    Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
    Samsung SCX 4521F All-In-One Laser Printer Logo
    554 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
