Question about Craftsman Garden
I have a Craftsman LT 1000 riding mower that just quit running. Won't turn over or anything. Manual suggests checking fuse as one of the options. Only problem is, I can't find the fuse! Manual says it is behind dash but I don't see it. Anyone know??
Will a craftsman snow blade with a model number of 486.244121 fit on a craftsman tractor model number of 252540? If not, why?
Posted on Nov 14, 2009
  • 486 Answers
Start with the easiest thing first !
1) jump start the battery from you automobile, or install a charger for an hour. This will tell you wether you battery or connections are good.
If it started with the jump, before you replace a battery:
2) clean the cable ends and make sure cable hardware to battery posts are good and clean.
If it started with the jump, then you know the fuses are good.
If it did not start with the jump or cleaned and charged battery,
3) check the in-line fuse. Located between the key switch and the solenoid, in the wiring harness, normally behind the firewall behind the engine, or in front of the dash close to the fuel tank (if the battery is under the seat)
4) some Sears tractors use a 'relay' also located on the firewall.
Note: for now, let's see how this works. Let me know if you need further assistance. It can get more complicated, but let's keep it simple for now. rwvanlue
Posted on Nov 12, 2009
5 Suggested Answers
  • 8 Answers
SOURCE: how to replace deck belt on lt 1000 craftsman
there are several belt guards that you will need to loosen then the belt will slip right on. having someone hold the clutch will make it easier, and the belt diagram should be on the deck. If not, these are common mowers, so a search for this or a friends/neighbors mower may hold the answer. Be sure to re tighten all guards or your belt will pop off and wear out very fast against these metal parts
Posted on Oct 16, 2009
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
  • 19 Answers
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
Posted on Jul 19, 2010
richroth
  • 9472 Answers
SOURCE: I have a craftsman lt 1000 riding lawn mower and
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Posted on Oct 18, 2011
Fuses lt 1000
Right side of mower as you are sitting on it under the gas tank. Look for the fuse holder. It takes a two pronged fuse like a car would.
Jul 07, 2014 | Craftsman Garden
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 1000 mower I am having problems with
I have a LT 1000. I drilled out the holes in the gas cap. If they plug, you will notice the gas tank gets sucked in from the vacuum.
Gary
Sep 20, 2011 | Craftsman Garden
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Possible carburetor problem? Mower runs for
Apr 19, 2009 | Craftsman Garden
Garden Logo
778 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
