Question about Certance Internal DAT 72 (cd72lwh-s) DAT Tape Drive
Certance DAT 72 tape drive stopped communicating with PC
Internal Certance DAT 72 tape drive no longer seems to be "connected" to Veritas Backup Exec software. I can't even "inventory" a tape, eject a tape, etc. Was all fine the day before and ran a backup. It is an older drive, but didn't know if they would just disconnect and stop like this or not. I have also powered down the PC and back up. Still no joy.
  • scott_mckinn Dec 31, 2009
    Another thing to check first: Veritas Devices tab > All Devices > Administrator > make sure not set to "Pause."
    Thanks for the detailed outline of suggestions in response thread. I found a local tech that I believe went through these very re-seating and driver reinstall steps from what I observed. But, in the end, the drive still would not engage from a software driven command. Yet, on the Veritas Devices tab, it correctly identified the tape that was in the drive, so it was reading in the reverse just fine. This made it seem like the drive must be functioning, so we didn't quite give up.
    Then, on the Veritas Devices tab, we just *happened* to right-click on the Administrator line under the All Devices listing and noticed it was somehow set to "Pause." We took Administrator off "Pause" and *everything* started working again.
    We all felt really dumb, but we (internal admin and *2* different techs) hadn't checked that before or during other diagnostics, so it's possible this had been the problem all along.
    So, I *highly* recommend that you check this first, then go to the more involved steps.
  • 19 Answers
We have had the same problems with HP drives and Veritas. In our case it was not the drive per se. While I am assuming that based on the date of your post that you have moved to another solution, however, I will provide for you what we did.
First shut all down, disconnect the tape drive from the scsi cable, then restart. Go into computer management and turn all your backup exec services from auto to manual. Now go to devices and do a rescan. Once this is done and you see no tape drive whatsoever in the devices shut down the server. Reconnect the scsi cable to the drive and restart.
Go back into computer management, back to devices and rescan for hardware changes. Do you see it? If so, good! Sometimes a re-seating of connectors will do that. On the other hand, it could also be a tape driver from Veritas that just doesn't work (my case), take the original driver cd that came with the unit and start that loading up. Can you see it now? Can you use windows backup to access the tape drive? Now go into services and start the services individually. Go into backup exec and see if you can read your tape. Go back to services and reset all services back to auto. If you ever have to reinstall/upgrade backup exec, think twice about using their drivers.
Posted on Dec 30, 2009
  • Jeffrey McMorran Dec 31, 2009
    Thank YOU for the information and that is great that it worked out. Have a great New Year!!
NEED DRIVERS FOR STD224000N
The driver for this Archive > Seagate > Certance > and finally Quantum drive was included in Windows. Try Window Device Manager > select the drive > properties > update driver > Can Windows Update select No not at this time > Install from a list... > Don't Search...> Tape Drive > try either the Standard tape drives DAT driver or a Compaq DAT. If none of those work you are probably out of luck.
Jan 07, 2011 | Certance Seagate® Scorpion 24...
After a full back-up was made, the tape stays in the drive
Click Start, then Run, type in services.msc and hit enter
Look for the Symantec (Veritas) backup Exec Tape engine service and stop it by right clicking it and hitting stop.
Eject the tape.
Restart the service.
Dec 17, 2009 | Veritas Backup Exec 10 for Windows Servers...
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Jul 25, 2008 | Certance (CL1001-R) Ultrium Tape Drive
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
New tape drive
Didn't realize i had to install a Veritas tape driver to allow Veritas to see the drive.
Mar 24, 2008 | Veritas Backup Exec 10 for Windows Servers...
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
My Tandberg LTO Drive isn't working with Veritas Backup Exec
When you say 'rolled back' did you use a system restore function? Do the backup logs say why they failed?
Sep 12, 2007 | Tandberg Data 420LTO LTO 2 Tape Drive
40 GB Data backup cartridge keeps ejecting
When was the last time you cleaned out the tape drive. You could get errors like that if the drive is dirty! Regards, Armando
Apr 23, 2007 | Certance Travan 40 GB (stt3401a-sst)...
Certance Internal DAT 72 (cd72lwh-s) DAT Tape Drive Logo
156 people viewed this question
Top Certance Computers & Internet Experts
David Payne
David Payne
Are you a Certance Computer and Internet Expert? Answer questions, earn points and help others
