Question about SanDisk Sansa e250 MP3 Player
Help me!! My Sansa was messing up, I deleted everything on it and tried to format it, it wouldn't let me do that because there were files on there that i was unable to delete.. NOW i've given up on that, i just want my sansa back, and I can't even re-add what i deleted because it says the files are in use, which their NOT. I'm so frustrated because I am pretty knowledgeable about this stuff. Theres a file on there (on the cpu only, not the sansa) called "WILDHO" haha I think its a virus? Please tell me what I can do.
  • Anonymous Apr 10, 2008
    All I got, as far as instructions, was a copy of pages 3 and 4 of the owners manual. I want to know how to delete either individual songs or all of the songs so I can start over.
  • lil-chanidy Dec 21, 2008
    My sansa dosn't work after i satrted charging it started teling me
    " Not enough space for music 80 MB " also i downloaded more music then tried 2 erase it but they wont erase what can I do ca some 1 help me
  • 27 Answers
It is difficult to explain not knowing exactly what I'm looking at, but I have the feeling that the files that are locked on the Sansa are probably marked "READ ONLY." I am unfamiliar with your exact player -- But I know the one that I have (A Sansa Express) allows me to look at the files in a directory format like a disc drive. If you are able to do this, look at the file in question by choosing the "properties" tab while doing a right mouse click. In the Attributes section, are you able to change these parameters? I'm only speculating -- so don't hold it against me if I'm wrong.
Posted on Jan 08, 2008
Reformatted sansa e250 need help
When you format it, it deletes everything on the player. You'll just have to put everything back on it.
Jun 20, 2009 | SanDisk Sansa e250 MP3 Player
Sansa E260- Cannot delete songs/ won't respond to modified files.
In order to sync the files with media player the device must be in MTP mode MSC mode is used for drag/drop file updating. try setting MTP and then sync it or just open the drive file in my computer in either mode to update the file list.
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
Files invisible to Windows still play, can't delete.
Format
This will format your Sansa c200 player’s internal memory. (and erase all songs therein)
1) Select Settings from the Main Menu.
2) Select Format.
3) Select Yes to format the internal memory or No to cancel.
Feb 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e260 - Video Problem! D:
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 22, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e 260 will not work
Sounds like you need to reset your sansa, should be in the settings under factory reset, and/or format. THis will delete everything.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Erase everything from my Sandisk M230
Hello!
Im affraid to answer this question. because i only gain' thanks for trying" but its ok.
In your case , If you want to delete all files in your sansa, maybe you can delete it by formatting your sansa disk. You can find maybe the format on the menu and select format the disk(something like that.) Or you can connect the sansa to the computer and delete all files in there. You can browse your files in the my computer and select the drive created by computer when the sansa is connected.
may this help, melnavz
Mar 06, 2008 | SanDisk Sansa e200 MP3 Player
How do i delete videos off of sansa e260(4Gb)
Do this.
Go to computer
And see the removable disk.
Locate the one that its attached to
Right click
Format it
It should work.
Dec 22, 2007 | SanDisk Sansa e260 MP3 Player
Deleting files
You can format the device thru My Computer. Right Click on the "Removable Disk" under My Computer and select Format. This will delete everything off the device. Best of Luck.
Sep 18, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa Shaker
You should not use a program to manage your music on the Sansa Shaker. Just use My Computer to manually drag & drop files onto the device. Also, you can format the device thru My Computer, right click on the device and select format, this will erase everything on the device. Best of Luck
HOW DO I FIX THIS PROBLEM?????
I had the same problem with mine. I messed around with it, and now it's working again. Here's what i did. Try this, and let me know if anything happens: Take out the battery. Plug the mp3 player into your computer, without the battery. Find the MP3 player under "My Computer." Right-click it, and click "Format" After formatting, leave it plugged in for a while. Add a song to it, then unplug it, and turn it on. Hopefully, the song will show up. Hope it works! -Yockub
Mar 09, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
