Question about Solis Crema SL-90 Espresso Machine
Solis SL 90 occasional pressure loss, only a few drips of coffee before it switches itself off. Cleaning sometimes helps or not using for a bit.
  • 1,089 Answers
HI
There are a few things that can cause this. If it brews without the portafilter in, then your coffees is too fine or you have a blockage in your basket if it has a ring in the bottom. You can clean the basket by using espresso machine cleaner like Cafiza or JoeGlo. Automatic dishwashing detergent works in a pinch also. 1/4 teaspoon in the basket then brew like normal but stop after 3-5 seconds and let set for 1 minute. Repeat this for about 5 - 10 brews then rinse the basket and run 2 - 3 long shots of just water through the basket (brew) to thourghly rinse the basket.
If it doesn't brew with out the portafilter in, then you have a blockage in your brew head. There is a screw that holds in the dispersion screen. Above that is a larger screw that holds in a check valve. if you can get the check valve out see if water will run through. If not your blockage is in this tube. run a heavy wire up this tube for about 4 inches. Twist the wire as you go. Test to see if you can get water through. If so reassemble and do a descale through both the wand and brew head. Use a strong descale the first time and then do a second. Descale 2 to 3 time a year to prevent this.
Posted on Nov 12, 2009
Testimonial: "Very helpful, I'd wondered if it might be the basket."
Water is dripping from the head while using the steaming wand. It seems like a seal is bad--could that be the case?
first check the water supply which where is connected thru your machine and lastly the gasket which controlling volume of water thru your machine
Jan 08, 2011 | Solis Crema SL-90 Espresso Machine
Solis Crema SL90 not heating water
Yes it can be repaired, sounds like the thermostats might have tripped.
Jul 02, 2010 | Solis Crema SL-90 Espresso Machine
Broken handle on filter holder
Hi
Yes, you should be able to buy them. Let me know if you can't find one, cause I have one.
Apr 19, 2010 | Solis Crema SL-90 Espresso Machine
Looking for Parts for Solis SL 70
I also called 888 437 8340 and they sent the switch right out. Very helpful phone rep. The company is called Empire Fulfillment.
May 23, 2008 | Solis Crema SL-70 Espresso Machine
Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
Mar 02, 2008 | Solis Crema SL-90 Espresso Machine
Solis Crema SL-90 Espresso Machine Logo
187 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
