Question about Mitsubishi CS-27405 TV
Mitsubishi cs27403c tv problem
When t.v. is turn on ,single horizontal line appear on screen.I know it's in vertical section but i can't identify the vertical section .I need a schematic diagram.I really appreciate if you can provide me a schematic diagram. I'm not an expert yet.
Thanks Ehdy
  • arnelf Apr 21, 2008
    Same problem of horizontal line at the middle of the screen. Already adjust the screen and the focus knobs on the flyback. What is the solution to this problem?
  • Anonymous Nov 11, 2008
    Same horizontal line. I as well already tried adjusting the knobs on the back for focus and all. What else could I try?
    New Friend:
Please show me vertical section diagram
Posted on Nov 17, 2013
    Problem Solver:
  • 9 Answers
Kindly...see first the flyback and adjust the screen if the horizontal line still there adjust the fucos....
Posted on Jan 08, 2008
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
How do i get a picture in the "pp " feature ?
Jun 25, 2011 | Mitsubishi CS-27405 TV
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
My tv has many lines in the screen. what kind of problem is this and what does it need to be fixed?
You may be suggesting a convergence problem..when the blue and red boxes will not center. You have bad grounds on the convergence ICs. Resolder or replace theses ICs. Or you may be asking about a problem in the vertical section. Vertical problems will appear as horizontal lines on the TV. In this case you have bad capacitors near ithe vertical IC and must also resolder or replace the vertical IC.
Nov 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Apr 12, 2007 | Mitsubishi CK-35308 35" TV
Televison & Video Logo
162 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
