Question about Ace Hardware Garden
NEED MANUAL FOR POWEGLIDE 18" CORDLESS HEDGE TRIMMER MODEL #60101381
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
boscia
  • 163 Answers
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
cactus bob
  • 267 Answers
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
this is the same attachment as mantas tillers use to make there tiller motor into a hedge trimmer try there website for a download ................if this answer helped please rate 3 or 4 stars this will keep me in the paid answer department
Posted on Apr 02, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
Broken Tooth for GT90 Hedge Trimmer Gear
I need a manual for UT 31840 18 volt cordless hedge trimmer
Jul 04, 2013 | Dewalt Garden
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
The instruction books indicates that a green LED light will come on when charging and go off when charge is complete. Our NHT518 hedge trimmer only shows a red light, and after charging all night the red...
Check the contacts on the charger and battery are clean. They can be cleaned with IPA or meths.
Make sure the battery charger is slid fully onto the battery, it may take a little bit of pressure to do this because of the springiness of the contacts.
May 02, 2011 | Black & Decker NHT518-1 18-Volt Cordless...
What kind of oil and where should I oil it with? The teeth are starting to stick
I prefer to use honing oil, but clean the build up off and lube with most any oil, wd-40 may help in cleaning but is not a lube.
Oct 06, 2010 | Black & Decker 18 Volt Cordless Hedge...
Think we need new blades for our cordless hedge trimmer. Where can I get them??/
Try the place where you made your purchase. If they don't have them in stock...Maybe they can order the correct blades for you. If they are not a Black and Decker dealer. Try on Line at their website.
Oct 06, 2010 | Black & Decker Hedge Hog Cordless Hedge...
I have a GMC cordless hedge trimmer, unfortunately the motor was worn out. I would like to know where can I buy a new motor and replace it. The model of my trimmer is Hedge Hog HT 18V 460mm. Thanks for...
Try going to www.dewaltservicenet.com. It is a site that covers your Black and decker hedge trimmer. You will need the model number off the unit to find the parts you are looking for.
HTH
Good DAy.
Nov 23, 2009 | Garden
Garden Logo
61 people viewed this question
Top Ace Hardware Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ace Hardware Garden Expert? Answer questions, earn points and help others
