Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore 18 top freezer doesnt freeze completely. refigerator cools to 48 f .
  • 2,237 Answers
Possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Posted on Nov 13, 2009
The top of my refigerator is freezing in the back
Hi, the problem you are having is the defrost timer not going into defrost mode when the timer says to. They are normally located in the bottom back of the unit and will have a screw driver slot on it. It may be stuck in the off position. Turn it a click with a screwdriver and see if this starts the defrost mode and other problems. Is the evaporator fan in the freezer up and running? If not, this motor must be on. Keep me posted on this and we can get to the bottom of the problem.
Sincerely,
Shastalaker7
Mar 03, 2010 | Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refigerator
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Aug 26, 2007 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
