Question about HP Compaq nc6000 Notebook
I installed my new hid s and the one that wasnt working works and now the opposite one doesnt work . and i checked the bulb that wasnt working and it worked
  • 247 Answers
Sounds like you have a car headlight problem, not a computer problem.
Posted on Nov 12, 2009
Hid headlight on 2005 vw beetle won't work
For many European cars, you might need to add capacitor to ensure the HID working properly.
You will probably need this
CAN BUS Error Free HID Decoders Installing HID Conversion Kit
Jan 27, 2014 | Cars & Trucks
HEADLIGHTS DO NOT WORK, BUT HIGH BEAMS DO AND SO DO TURN SIGNALS AND SIDE MARKERS
The HID requires a ballast, did you do any rewiring? Did you check the fuses? Unplug the relay either hi or low, use jumper wire between terminals 30 and 87, the lamps should work, I'm talking about your regular lamps. If they work with the jumper, then check control side of relay.
Mar 06, 2017 | 2009 Chevrolet Malibu
My right side headlight not working on A4, 2007. Install new H7 bulb from Audi but it did not work. I install the right bulb into the drivers side and it work. I suspect an electrical problem. Possible no...
if it is a hid light system they are famous for the balast going bad. follow the wires from light bulb. if they go into a box then its a hid system and it is the balast box that needs to be replaced. also check the fuses, sometimes there are seperate fuses for each headlight.
Mar 09, 2013 | Cars & Trucks
Mazda 6 sport sedan break lights not working after hid light conversion
Instructions Open the rear deck lid on the Mazda 6.Carefully remove the plastic finishing cover from the license plate light housing, using a small flat-head screwdriver to release the locking tabs. Pull the cover downward and off of the deck lid, exposing the license plate bulb.
Remove the old light bulb from the license plate bulb socket by hand. Wrap your new one in a paper towel and do not touch the bulb with your bare fingers. Insert the new bulb into the light socket. Install the finishing cover onto the light housing and push it upward until it clicks and locks into place.
Repeat Steps 2 and 3 to complete the LED light conversion on the opposite side of the deck lid. Test the new bulbs by turning on the headlights on the Mazda 6.
Mercedes Parts.
May 25, 2012 | 2004 Mazda 6
Hid headlights dont work ,new bulb installed. is there a computer that controls the lampc
both lights? at the same time? you replaced 1 bulb or both? there are several fuses,40 amp fuse, headlamp relay, fuses are all good? any other lights not work? Are you sure it has HID lights?
Sep 15, 2011 | 2002 Lexus IS 300
New HID low beam bulb in my 04 Navigator
Sounds like the ballast similiar to the ones in flourescent lighting may have gone bad and that is why the bulb is not lighting up.
May 19, 2010 | 2004 Lincoln Navigator
I installed HID headlights and fog lights about 2 months ago and the passanger side went out. i took the drivers side bulb and put it into the passanger side to see if the bulb or the ballast was bad and...
The headlights run through a relay (#46) through the BCM. If the relay were bad (very common and has a recall) both lights would not work. Sooo, I'm thinking check the wiring and pigtail that goes to the bulb. People that use Silverstar halogeon bulbs will burn that wire and or the connector. Make sure these are sound, check for power at the connector too.
Apr 17, 2017 | 2007 Chevrolet TrailBlazer SS
1 headlight works intermittently other doesnt work.Side and full beam work perfectly
Are these conventional bulbs or HID? Probably bulb is burnt out, but there is still enough filament flapping around in there to complete the circuit under some circumstances. Either that, or the bulb itself is not seated firmly in its connector.
Feb 27, 2009 | 2007 Ford Edge SEL Plus
Passanger headlight bulb inop
disconnected the HID ignighter. used a T20 to remove bulb cover. pulled out bulb and installed new bulb. DO NOT TOUCH THE BULB WITH BARE HANDS!!!
Nov 23, 2008 | 2004 Acura TL
HP Compaq nc6000 Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
