Question about Cell Phones
When I press the power button, before I unlock it, there is a fine line ging across my screen. It goes a way when I unlock it. Why is that line there? Also, is there going to be a way to receive my outlook mail on it?
My i phone wont turn on, has a black screen with a black line running across the screen from side to side can i fix this ?
try this: press the home button then after several seconds press the power button (home and power button) if its not working then i think it has a hardware problem.
good luck
Feb 09, 2013 | Apple iPhone 3G
My i2352Fh monitor has developed a white vertical line which tracks back and forth across the middle half of the screen how do i get rid of it? the screen is 3 months oldn
Thanks Melony - had exactly the same problem - your post above helped me fix it...... Here is how to fix it .
  • On the base of the screen press the Menu button (far right),
  • Then press < or > to get to the Extra (looks like a screwdriver and spanner) and press Menu again to Enter.
  • Press < or > until you have selected the RESET and press menu again to Enter.
The line should be gone. Close the menus and all should be fine. I hope this helps someone. I searched the internet and this was the only post that gave me a clue. Thanks again.
Dec 16, 2012 | AOC I2353FH 23" WIDE Monitor
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
I have unreadable lines across my screen
Hi You need to try using different monitor/lcd to find out if the cpu or the monitor is the problem
- If the screen on the monitor will work fine after using a different monitor or lcd it only means that the cpu is working properly and also it means that the problem is the the monitor/lcd and you need to bring it to the repair center or you need to replace it.
-If the screen on the monitor will encounter the same problem it means that the integrated video inside your cpu is busted. if your computer is still under warranty you better call the manufacturer.
-Also you can try the safe mode. after switching on the computer press repeatedly the F8 button on your keyboard and it will direct you to the diagnostic menu of windows and all you have to do is to choose SAFE MODE and hit the enter button then you need to wait until the windows load if the appearance will work fine it means that you need to reinstall the software driver of video graphics adapter.
Feb 21, 2012 | Gateway GT5064 PC Desktop
IPhone slider won't slide all the way across
I'm having the same issue, have you found any solution?
Apr 30, 2010 | Apple iPhone 3G
Horizontal lines on the screen after the picture is taken
Remove the Battery from the Camera then press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn on the Camera and reset it to the original factory settings by selecting the "Initialize" option under Setup1.
If the issue persists then service will be required.
Sep 08, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
