Question about Roper RAS6233KQ Top Load Washer
Wasing macine won't empty water but if I put it on spin it will empty it.
  • 11,896 Answers
Sounds like the selector switch is faulty.
Posted on Nov 12, 2009
Try spelling it " washing machine"
Posted on Nov 13, 2009
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
How do I remove bosch pressure chamber 5031-6882-5007-9
Two way radios are not washing machines...
Peter
Nov 22, 2012 | Radio Communications
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
My machine will not spin dry and empty the water after a wash, the lights will just blink and the machine will stop.
My machine won't spin or drain and just goes on and on for hours not taking notice of the cycle I put it on, can anyone help?
Jan 03, 2011 | Whirlpool AWG5122 Front Load Washer
Wasing machine stopped begore end of spin cycle half full of water
I dont know what type of machine you have.
It sounds like the pump is the cause of the problem,it has stopped pumping the water.its probably blocked with debris.
May 29, 2010 | Washing Machines
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Roper RAS6233KQ Top Load Washer Logo
78 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
