Question about Toys
What color wires atach to theleft hand 0-31 mth
What color wires attach to the left hand 0-31 mth switch track ? the manual does'nt tell you the color code
Was able to find the instructions for the swith track
Posted on Nov 13, 2009
Left hand turn signal not working at all
First replace the turn signal light bulb. If that does not work check the voltage at the signal light bulb socket .there should be 12 volts there when youput on theleft turn signal. Normally thefuse for the signal should be for theleft and rightturn signal system. Sinceright turn signal is fune then it cannoy be the fuse.
Nov 25, 2017 | Cars & Trucks
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Feb 07, 2015 | Crafts & Hobbies
I have a pair of vintage 027 remote switches (right & left hand). When I flip the lever on the remotes, the track will only switch in one direction. I can't get it to go back.
First reverse the remote wires and see if the switch track throws in the direction it didn't before. If it does then there is something wrong with the remote switch. If not, then you can wire the switch terminals directly to the power source and turn on the power and see if the switch throws. First do center and right terminals and then center and left terminals. If no sound or buzz the solenoid may be bad. If buzz then see if the rails are stuck and can't move. May need grease.
Jul 30, 2011 | Lionel 027 Left Hand Remote Control Switch...
Need a wiring schenatic for 66v
I answer questions for free.
I know electrical wiring.
I have an image of the 66V, but it does not show the screws or color of screws.
I cannot find a manual.
SO, if you can 'add a comment' to this post and tell me the color of screws on each side of switch, I can tell you with 100% certainty where your wires go.
Otherwise I will shoot wild and see if I can hit the target.
1) One side of the switch has dark-colored screws and the other side has brass screws. The Hot black wire from breaker attaches to the dark-colored screws. The wires going to Load (fan, light) attach to 3 brass screws.
2) One side of the switch has brass-colored screws and the other side has silver colored screws. The Hot black wire from breaker attaches to brass screws. The wires going to Load attach to 3 silver screws.
Oct 30, 2010 | Broan-NuTone FAN CONTROL SWITCH
My heaphones seem to have a false contact. But the left sife (side not atached to the cord) works just fine, its the right side, where the cords goes in that theres a problem. that side doesnt work. if ...
Has broken the copper wire inside the sheath. My email is: doctor.walkman @ gmail.com, tell me the make and model of her headphones and a photo detail. I'll try to help her.
Oct 18, 2010 | Audio Players & Recorders
How do I install this device? I connected a white
You have almost got it, but the wires aren't separate the correct way. On one side of the device your going to have your power. The side that's power will have two brass colored screws. You need to find your power wire and splice two wires to it then connect those two wires to your device on the power side this should leave you with two wires. If you happen to have two white wires now, you are going to splice them together with a third wire (called a pigtail just as you did with the blacks on the power side). Now on the non-power side the screw colors should be brass and silver. You will attach your white wire or bundle of white wires using the pigtail to the silver screw. This is the neutral for your receptacle. Then the black that goes out to your light will get attached to the brass screw. The problem you had was then a neutral was being attached to the switch as well as the receptacle and a switch requires no neutral, a switch is simply a break in the power line.
Jun 07, 2010 | Leviton Combo Switch Receptacle - 5225-T -...
Have hand control wireing problem ,,,, need to know what color wire does what ,,,, got the left hand control to wire up on a older bike,,,,, hooking up trun sigals and head light control,,,,what color...
This information applies to the vast majority of Honda motorcycles. Colors for the right handlebar switch are: Grey sends power to the turn signal switch. Light Blue goes from the turn signal switch, to the right turn signals. Orange goes to the left turn signals. Light Green goes to the horn button.
The left handlebar switch: Yellow With Red stripe goes to the starter button. Black wires take power to the headlight switch and the kill switch. White goes to the headlight low beam, Blue to the high beam. Brown / White goes to the tail light, running and instrument lighting. Black / White comes from the kill switch and delivers power to the ignition coils.
I hope this helps.
Nov 06, 2009 | 1982 Honda VF 750 S
Part missing from clutch trust arm on ford escort
Hi. The same thing happened to me yesterday and I called out the RAC.
Fortunately the culprit was left dangling on the end of the clutch cable, what the nice Rac man described as a 'counterweight'. This is a roughly 2inch cube unit, mainly rubber, that clicks over the end of the arm and the cable itself fits into.It seemed to fit back in position after a little lubrication and a bit of wiggling.
Only fitted to some cars, apparently , (and not mentioned in my Haynes manual). Mr Rac not sure if it should be bonded to the arm, or just left 'clicked' in place.
Hope this helps a bit. Boatyman47
Sep 14, 2009 | 2001 Ford Escort ZX2
Toys Logo
133 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
