Question about Singer Featherweight II 117
My bobbin winder has threads wound around the bottom of the post and will not rotate. How can I remove these threads?
  • 1 more comment
  • hhpayne Nov 13, 2009
    I have tried tweezers and that just breaks the thread. There are about 6 ends of thread jammed into the bottom of the post and I really need to loosen or remove the post. Any more ideas? Thanks.
    I have threads jammed in the base of my bobbin post. Using tweezers doesn't work and I would like to know how to remove or loosen the post. Now everything is jammed and machine will not move forward or backward.
  • 3,741 Answers
Ok i am giving you the link to the instructions with pictures on how to do this: here is the link:-- http://www.gammill.net/documents/troubleshooting20090803.pdf
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 13, 2009
    President:
  • 2,976 Answers
The easiest way, is with a tweezers and rotating the palm wheel backwards.
How to thread the bobbin winder
google it by make and threading instructions Google
Mar 15, 2017 | Sewing Machines
Bobbin winder not working
none I have ever had CATCH the thread . you have to thread to the bobbin and hold the end till it gets a good start .
Feb 12, 2016 | Sewing Machines
When winding the bobbin thread slipped off tension disk and wound around the bobbin shaft. When I removed the thread the bobbin will not fill with thread.
Well, you COULD get this fixed -- or you could purchase an inexpensive bobbin winder and skip the whole issue. Does a better job, too.
Oct 30, 2015 | Singer 7258 Sewing Machine
How do I wind my bobbin
Bobbins are wound at the top of your machine. There is a post on the top right that your empty bobbin is slid onto, a chrome latch that pushes towards the bobbin. A spool of thread is set into another post, usually right behind the little bobbin winder post. A length of thread is guided thru a post at the opposite end and brought back to the bobbin-winder post. Nowthe power is engaged. At the time of power applied, the post upon which the bobbin is seated on, spins and accumulates the thread. Note: Bobbins must be removed from underneath the sewing stage to be rewound with new thread. Replacement is much the same as removal, with a plate that slides away, a reveals the shuttle where the bobbin is located. The rewinding happens at the top.
Nov 03, 2014 | Sewing Machines
Bernina 135 bobbin winds unevenly
If you are finding that the bobbin is winding with more thread towards one edge of the bobbin than the other, the bobbin winder motor needs to be adjusted so that the angle of the winder shaft is properly aligned with the tension disc next to the head cover. Unfortunately, unlike many of the other models, you have to remove the covers on the Activa range to get at the adjuster. There is a spring-tensioned screw just to the left of the bobbin winder motor that adjusts the angle of the motor and therefore how it loads the bobbin. If the winder is loading the bobbin with most of the thread towards the bottom edge, the screw should be turned clockwise and if most towards the top, it should be turned anticlockise. Make adjustments until the thread is winding evenly or, at least, towards the centre of the bobbin.
If you are finding that your bobbin is being loaded somewhat randomly, make sure you are using the vertical spool holder to hold the spool and that you've got a foam pad under the thread spool. Route the thread through the thread guide before winding around the tension disc in the correct direction (see the arrow on the case) and ensure that the spool and thread do not vibrate unduly when the bobbin is being wound. If you let the spool vibrate whilst the bobbin is loading, it may result in varying tension on the thread and uneven winding onto the bobbin.
Oct 02, 2011 | Bernina Activa 130
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
My bobbins sometimes don't wind right. The thread gets all tangled at the bottom of the bobbin instead of winding evenly. I'm sure it's user error because sometimes it works. Hoping you can help me figure...
when the thread is on the spool pin
1.guide the thread around the bobbin winder thread guide
2.insert the thread through the hole on the bobbin, threading from the inside to the outside
put the the bobbin spindle
3.push the bobbin winder spindle to the right (if you have a electronic machine the LED display
will show SP)
4.depress the foot control, when the bobbin is fully wound, stop it, & push the bobbin spindle to the left, cut the thread & remove it from the spindle
Nov 17, 2010 | Simplicity Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Singer Featherweight II 117 Logo
44 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
