Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Whirlpool refrigerator stopped cooling. the
Whirlpool refrigerator stopped cooling. the compressor is very hot! The cooling fan that appears to blow on the compressor in the back is running. model is actually ed5pha but it's not listed in the choices below.
  • D. Floyd Kolb
    D. Floyd Kolb May 11, 2010
    The compressor is very hot because it is trying to run and cant because something is either tight inside or broken. You can try to pull the plug for over night and let it cool down sometimes this is a temporary fix. But eventually you will have to replace either the compressor of the whole refrigerator. Replacing the compressor will be half or more of a new unit. Any chance this is warranty?
  • Whirlpool Master
  • 1,606 Answers
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Posted on Nov 13, 2009
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Whirlpool ET18JK Not cooling, fan runs, compressor kicks on, blows hot air?
Easy tests, put your hand on the compressor, if it is vibrating it is running. Touch the two lines coming out of the compressor, if they are both warm then the valves are shot on the compressor, if they are just regular temp then you have a refrigerant leak, if one is hot and the other is cool then you may have a blocked cap tube, which means a $600 fix. If the compressor isn't turning on I would check the thermostat for bat contacts. When you set it to low there should be a small ammo unit of resistance and if you turn it off the meter should say OL. Good luck
Sep 04, 2012 | Whirlpool Refrigerators
I have a Whirlpool GC5SHEXNS00 side-by-side refrigerator that has stopped cooling. For quite some time the center column was hot to the touch, but it maintained the ability to cool. Now it no longer cools...
If the center wall was hot then your defrost heater was stuck on, now with no cooling it could be you burnt out the compressor or the main board could be fried. Not good either way, it might be time for a new one. Sorry
Nov 09, 2010 | Whirlpool GC5SHEXN Side by Side...
The gasket around my refrigerator is too hot to touch, what is wrong?
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Jun 07, 2010 | Whirlpool Refrigerators
Heated panel
May 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Very hot frame
May 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not cooling
hi thanks for the question you say the fridge is still running is the fan in the freezer running at the back is the compressor running if the compressor is not running and is very hot it could be a bad compressor is there a fan down by the compressor if there is a fan by the compressor is it going if not replace the fanthanks the appliance doc
Aug 14, 2008 | Whirlpool ED2FHEXN Side by Side...
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
811 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
