Question about Proform Crosswalk 500 Treadmill
Pro-Form Crosswalk Plus Treadbill back leg extension
I recently bought a Pro-Form Crosswalk Plus treadmill on Craigslist. I did not receive a manual with it, but it was already assembled, and it works fine.
The only exception is that I realized after using it several times that it is on a constant incline. After checking it over, I found that the back has a bar with legs and wheels on it that I think are supposed to extend to create a flat walking surface, as the front end can not go down any further without sitting on the floor.
I have pushed, pulled and searched for buttons and knobs everywhere to try and make the back legs extend, but I just can't figure it out.
I can't find a free manual anywhere online for this specific model, and I don't want to use my treadmill again until I fix the problem.
*Note, the product it is making me list is not the correct model, I could not find my specific model and it wouldn't let me type in one that wasn't listed.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 103 Answers
Iconservice.com has free pdf downloadable manuals for proform.
Posted on Nov 13, 2009
Testimonial: "Excellent! I was able to find the correct model and have fixed my problem. Thanks so much!"
  • Tim F Nov 13, 2009
    you are very welcome!!
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
When I plug in my pro form 370e crosswalk it doesn't turn on nothing happens
1) test the outlet wall, reset the c.breaker from your house, or tes the fuse if are blown.
if the problem NOT result and is o.k the c.breaker
2) test the power cord, for open
3) Eliminate any extension cord
4) test the main switch for open
5) reset the switch attached to the main switch.
6) tight any wires loose
7) reset the c. breaker or replace the fuse blown see the block.
God bless you
Jul 02, 2012 | Exercise & Fitness
My pro-form crosswalk 397 the track will not work. The lights display and it makes a sound but the track stays in place. I bought this on Black Friday and have only used it 3 times. Help!
INMEDIATELY LUBE the deck belt, maybe is WORN. and adjust the roller bearing see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
sincerely. God bless you
Apr 23, 2012 | Proform Crosswalk 397 Treadmill
I need screws to reattach control panel to my pro-form 590-ls crosswalk treadmill
Dear Sir:
You need to check you user manual. Anyway you must need 6 long screws philips for attach plastic-iron about 1 -1/2"-to 3/4" you can buy in any hardware.
You can download your user manual free http: //fitness.manualsonline.com or+go
www.proform.com go customer service and then parts & manuals put you model and serial number and download and ready.
sincerely.
Oct 08, 2011 | Proform Crosswalk 500 Treadmill
Pro form 780 cs console does not respond
Dear Sir:
Thank you by your request. I hope everything is fine in union with your family.
Now I will help you inmediately.
Please do the following:
ercupa190.jpgSchematic for Reed Switch
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Proform 780 CrossWalk Treadmill with...
I own a pro form Crosswalk model 405 and the instructions were lost in a move. How can I obtain a new copy?
This is probably not your ideal solution but just in case it is helpful here is a list of the models of the proform crosswalk 405, if you select your exact version you can purchase a new owner's manual.
Jul 20, 2011 | Proform CrossTrainer Treadmill
Describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
May 31, 2010 | Proform Exercise & Fitness
Jerky treadmill
Please check out this tip I wrote. Please let me know if you need anymore help.
Apr 08, 2010 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 500 Treadmill Logo
338 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
