Question about Olympus FE-310 Digital Camera
Hi Flash symbol on my camera appears but it will not flash when I take photo. When I take a photo with flash switched off it is brighter than with flash on.
    Problem Solver:
  • 5 Answers
Try setting different flash modes through guide
Posted on Nov 19, 2009
My photos are coming out dark on my Nikon D5100...should I be using an additional flash? An extra one attached to the camera? Sometimes they look dark on the live view and come out okay after the picture...
The build in flash, will be useful within several meters (15 to 20 feet) if it is really dark.
Your camera should be capable of taking pictures in poor light conditions. Try to shoot in automatic mode. The mode dail to AUTO. (green camera symbol). Then view the picture with info. There you can see the ISO, Aperture and shutter time. From there you can experiment for darker or lighter pictures. For this you can choose M, A,S or P.
In each of these modes, you can use the following steps.
On top of the camera, close to the shutter release button you see a little knob with a +/- sign. If you press that button, you should see a 0.
If you see a - figure, this means the picture you shoot all be darker than normal. If you see a + sign with a figure it means the picture will be brighter. While pressing that button and turning the command dail, you can choose -3 to +3 EV. That is much darker and much brighter.
If you shoot many pictures in bad light conditions, you could buy an external flash. A Nikon flash will work very good and automatic, with your camera, because camera and flash will communicate and help each other to make better pictures. Cheaper external flashes can work too, but most of the time you must change settings manual on the flash. Never use old flashes, that were build for analog cameras. They sometimes switch with a voltage higher than your camera can handle. The camera can be damaged by such a flash.
Dec 04, 2013 | Cameras
Flash is not firing
Very little to go on, but in every camera you can switch off the possibility to flash. How to switch it on must be very easy, because it is always in the top menus of every camera. Looking on the back of your camera, with the menu on, you should see a flash symbol, with a bar through the symbol, then it is off. Try to switch it on. If the symbol is on (without bar) look if it is dark enough so the flash should work. You also could try to reset the camera to the default settings. But is the flash still does not work something else could be wrong. Just try an external flash. If it does nothing, after you tried everything above, I can't think of anything else. Success.
Oct 24, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
When using flash it takes a couple of seconds to take photo hence picture is blurred
It's probably because you have enabled the slow sync flash mode.
To switch to the normal flash mode (auto flash) press your left directional key until the flash mode indicator near the top left of the screen (an icon with a "lightning" symbol) changes to an icon with a letter A next to the lightning symbol.
The slow sync flash mode is different from the normal flash mode; in this mode, the camera exposure duration can be a few seconds and the flash actuates at the beginning of the exposure. Although this is useful for certain photography techniques, you have to enable normal flash mode to take pictures in the normal way without blur.
Apr 28, 2011 | Samsung S760 Digital Camera
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Jul 13, 2008 | Canon PowerShot S5 IS Digital Camera
G9 flash
In your display, is the small lightning symbol appear on the screen? Try cycling through the various flash options by pressing the "flash" lightning symbol to the right of the monitor. If the flash is set to flash when there's not enough light at the G9's descretion (with an "A" next to the symbol) then the flash may or may not go off. I oftentimes set the flash to go off all the time if the camera is not doing it automatically (with the A next to the symbol). Being in Auto mode versus the other preset exposure modes affect the flash options available too.
May 20, 2008 | Canon PowerShot G9 Digital Camera
E:91:01 and Fash is not working
Gentlemen,
Please initialize your cyber-shot and this option is available in camera Menu. Hope this would solve problem.
May 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Olympus FE-310 Digital Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
