Question about Compaq Presario C700T Notebook
I turned computer off, it was installing updates and before it had finished i turned it back on. it has froze on installing updates and wont do anything.
  • 11,896 Answers
Remove battery pack, press and hold button for 5 seconds, put battery back in and restart.
Posted on Nov 12, 2009
Wont turn off
what model is the computer..what operating system are you using..how are you turning the computer off.? and is there any updates installing ..if the last is true then you have to let them finish then the computer will shut down on its own when there done
May 30, 2013 | Toshiba Satellite C655-S5125
I have a HP Pavilion dv6-3120us Entertainment Notebook. A update came from HP for the BIOS and while installing the update, it will not finish. Its frozen at 100% can you assist?
your options are wait for it to complete. Or power cycle it and hops it froze on downloading, and not during installing.
Manually download the bios update yourself and then flash it manually if it does come back up.
If the computer fails to boot up then you will need to use a recovery bootdisc and then to apply the bios update again manually as opposed to doing it in windows.
May 25, 2011 | HP Computers & Internet
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
Hi, I purchased a acer on 8/20/10. Updated with a new video card on 9/9/10. Worked great until 10/3/10. I was playing a game and the computer froze. I had to do a hard shut down. Computer came back up,...
Hello sir, if your hard drive and video card is new for now, then maybe your memory card is not enough for your PC. And please try to check the processor because I encountered some problems like that.
Oct 08, 2010 | Computers & Internet
Mp3 player is froze up. wont come on. New
Reset the player by pressing and holding MENU button for like 8 to 10 seconds.
You can also do a firmware update of your player. Connect your MP3 to your computer and download this LINK. Select "Save" to save the copy on your computer. After downloading, run the installer and follow the instructions to complete installation.
Hope this helps you. Good luck!
Nov 23, 2009 | RCA M4204 MP3 Player
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Laptop froze when trying to download Bios
The bios is a very touchy thing, if you screw them up you will have a door stop. Reboot the computer and start the bios update again. This time download and save the bios update to the hard drive and then run it from there. You should never run any type of bios program from the internet, you should ALWAYS save or burn to disc, then run. The internet is entirely to unstable for such an important update, if there's a glitch or loss of connection, even only for a millisecond, it can ruin your machine. If you cannot reboot and finish the update, get back to me and i'll see if I can get you through this.
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Freezing / no recognition by computer
it keeps freezing when i turn it on it says updating player then it updates it then it turns right back off ive reseted it like 10 times already and i just bault it today 2/24/2008 at wal-mart in borger,tx zip code 79008
Dec 31, 2007 | Philips GOGEAR SA6045 MP3 Player
Compaq Presario C700T Notebook Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
