Question about GoVideo Go Video DVD/VCR Combo
Dvd door allways hard to open now will not open at
Go veoio dvd vcr combo door allways hard to open now will not open at all
  • 11,896 Answers
Most likely either the door motor is worn out or it needs to be pryed open with a paper clip, pulled back all the way, and then hit eject button to see if it retracts.
Posted on Nov 12, 2009
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My govideo dvr4250 door will not open
remove the top of the case carefully and see what the door is caught on, or remove whatever debris might be there( hair, dust, etc) use q-tips and toothpicks to get the hard to reach places
Jul 01, 2009 | GoVideo Go Video DVD/VCR Combo
My dvd says open door will not open
You probably need a new dvd belt it is 24.25 mm rectangular. or it could've slipped off. Take off cover and move white wheel with teeth very gently until dvd tray starts to open then you can gently pull on it only pull it half way out and look in center of where dvd would normally be. There you will see the bigger and smaller wheels that control dvd player. look around for the belt. Make sure power is off when you do all this.
Dec 23, 2008 | Sony SLV-D350P DVD Player/VCR
DVD player problem
I had the same problem before.  I found a loose rubber ring which drives the door open/close may be the cause.  Use honey wax or candle wax to wax the ring will be most likely to solve the problem.  The only thing is you need open the box by yourself.
Jun 24, 2008 | Sanyo DVW-5000 DVD Player/VCR
Dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Jan 20, 2008 | Philips Magnavox DVD/VCR Dual Player
Sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
144 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
