Question about Whirlpool Duet GHW9150P Front Load Washer
When start button pushed, there is a periodic clicking noise from the back of the washer and won't start. what is the problem? is it the controller?
  • 11,896 Answers
That is the relay clicking. It is likely faulty. You can get parts and manual at repairclinic.com or partselect.com
Posted on Nov 12, 2009
Washer won't come on when start button pushed
It sounds like the User control and display board inside the machine is faulty.
Aug 08, 2014 | LG WT5101H Top Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
I hit power button then start start light flashes and wont start
If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
Oct 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool front load washer LHW0050PQ often will not start
Unplug the washer for 10 min. This will reboot the circiut board. Select one cycle. Selecting too many cyles in a short period or pushing too many buttons in a short period can overwelm the little brain in the board.
Apr 30, 2009 | Whirlpool LHW0050PQ Front Load Washer
Not working-push button controls-do not work correctly-sometimes
You need to replace your user interface board. Always order with the correct model number on the unit. This will eliminate you issues
Jun 07, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Front load washer maytag stopped working during wash
the start button is part of the board their.if you hear frying noise their when pushing it there ,you may have a failling board.god bless your way.Tom
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Need help
It may be the control panel board. Replace it you can probably do it yourself and that should solve the problem.
Jan 09, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
