Question about Frigidaire ATF6000ES Front Load Washer
Is there a filter that can be gotten at to clean? Reason -- very stale water smells are staying in the laundry now. Thanks for your help! ~~Canadian Query
  • 1 more comment
  • Narda Nov 13, 2009
    Thanks, hadn't tried that yet. Did do: wiped inside drum clean, scrubbed crap off door rubber, always leave door WIde open, often do extra rinses, NEVer leave clothes in after wash, checked drain hose for clogs, and all small animals in the house are accounted for!
    Didn't think there was a filter-- everyone else said their front panel comes off, but this one doesn't have that. Have done all the other stuff -- leave door open, never leave clothes in machine, scrubbed rubber on door, wiped down drum inside, checked drain hose. Next step will be some Clorox. Thanks for your response, 'ppreciate that.
    And thanks for your response, too. Clorox is next on my list of things to buy!
  • 236 Answers
There is no filter in the unit. Try taking the laundry out shortly after the cycle is done. Leave the washer door open if you can. A cycle with bleach may lesson the problem but again you will need to leave the door open.
The machine retains a small amount of water due the nature of its work. If your water is mineralized(hard) it will contribute to the problem as will leaving the laundry in the machine for a prolonged period of time.
Posted on Nov 12, 2009
Testimonial: "Clear, thoughtful answer, great response time."
  • Frigidaire Master
  • 43,501 Answers
I would try to run a cycle with a very strong clorox solution through your washer. It may be the easiest way to fix that.
Testimonial: "Didn't actually answer the question, but did give a great suggestion to help with the issue."
Fould smell coming from fridge - have cleaned out fridge but smell remains - are there any areas which could be blocked ?
Following steps will help you in finding the reason for having the weird smells:
* The drain pans under the refrigerator need to be removed and checked.
* The fan covers in the freezer section should be removed, check the evaporator coil and defrost drain pan.
* Check where the drain grommet goes into the drain closely, there could be a void in this area.
* There is always the possibility that the odor is from a liquid that has gotten inside the liner of the refrigerator.
* Did you replace any filter recently? If yes the water trapped in the filter head will stale and develop this type of issue. The problem may be resolved by flushing a gallon or two of water per day through the dispenser. If the problem does not go away, the filter head may need to be replaced. This would require a service technician to install the part.
Hope this helps.
Please feel to ask us if you have any further queries.
Shane
Apr 24, 2011 | Daewoo Refrigerators
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
The rubber gasket that lines the front of the inside opening has gotten dirty perhaps from dirty rags that should have been thrown away instead of washed. How do I clean it? Also, when I open the washer it...
It is pretty normal for a front load washer to devalope a mould like stain on thier bellow seal. Im not sure if the stain can be cleaned off but you could give it a go just scrubbing it but i would not advise using any harsh cleaners on it as they might deterioate the rubber. If you put a heavy cycle through on the hottest setting it should freshen up the unit and also leaving the door open when not in use will help prevent it going stale in there.
Hope this helps
Dec 01, 2009 | LG WM-2277HW Front Load Washer
Mildrew, stale water smell in laundry
Run a very hot wash on your machine with no load
Fill a bucket with a strong solution of soda crystals and pour it into the machine first
Add some more crystals to the soap dispenser
Use an old fashioned soap powder for a couple of washes as well and reduce the load slightly
Modern soap powders do not contain certain bleaches and soda and the 40 degree wash leaves body fats and oils inside which cause odours
Jul 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Musty stale smell
HI thanks for your question. ALL front load washers have the same problem.MY solution every wash use 1 cup of vinegar in time will solve the problem. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | LG WM1814CW Front Load Washer
Foul Smell from my GE Adora Washer..!
Having the same problem as everyone else , I make a habit of cleaning the filter once a month. I would like to advise people that if your load is heavy (such as scatter rugs) they will not spin out completely even when the filter is cleaned. No more GE for me!!
Aug 21, 2008 | GE WSXH208A Front Load Washer
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Frigidaire ATF6000ES Front Load Washer Logo
103 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
