2004 SUZUKI FORENZA - L4 2.0L 2000cc GAS FI N
Adjustment
The belt is automatically adjusted by the auto tensioner.
Drive Belt Routings
Fig. Accessory drive belt routing-2.0L engine
Removal & Installation
To install:
I really hope helped with this. remember rated this help. Good luck.
SOURCE: serpentine belt diagram:
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
The serpentine belt routing should be labeled on your radiator shroud. Look around the engine compartment like the hood or radiator fram suport and there should be a label with the the belt routing.
Good luck and hope this helps
if yours has the 3.8L then here is the diagram. Hope this helps
~ Zach
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
