Question about Canon PowerShot A520 Digital Camera
Lens will not extend when powering on. After few seconds give six beeps and powers off
  • 11,896 Answers
Either zoom is stuck due to debris, or there is not enough battery power or the system needs to be updated which a download can be found at the manufacture's website.
Posted on Nov 12, 2009
Upon powering on the Power Shot A1100 IS , Cannon log appears, then a bling byte sounds, then a series of six beeps and the Lens Error, Restart Camera message displays. The lens is retraced and will not...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Think it's time that you might have to weigh the options of either considering professional repair, or trying the more risky steps in the link.
Aug 27, 2011 | Canon PowerShot A1100 IS Digital Camera
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When turning on my camera the stays on for only a
2 possible problems..
This is due to one of two problems:
First and easiest: the batteries are dead. Im sure you know how to fix that problem.
Second: your lens is jammed. The camera tries to turn on and extend the lens but since it is stuck, can't do so and gives up, beeps, and shuts off.
To fix this problem, send it into a repair shop. it shouldn't cost that much.
I hope that helped.
Regards,
Jeep Brainy
Aug 11, 2009 | Samsung Digimax D53 Digital Camera
EX-510 Powers up, them immediately shuts down
I have the same problem is there a fix? marksugar@aol.com
Jul 12, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Error E18, the zoom is blocked
Hi
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
There are six screws holding the metal frame of the camera body together, two on each side, and two on the bottom. Remove all screws, pop the strap-hook plate (sorry, probably not the most technical term there), then gently lift the front plate off by pulling up from the bottom, and remove the back plate in the same fashion. These should come off relatively easily. This is what the camera should look like as you remove the plates:
img-5340-thumb.jpg?w=324&h=217
  1. Now, looking from the top of the camera, you should see a small motor on the left side, as shown below (it’s beneath the cable with a “22” written on it):
    img-5346-thumb.jpg?w=324&h=217
  2. Take your screwdriver (or another small instrument) and gently try to rotate the plastic piece attached to the motor on the left side, as shown below:
    img-5359-thumb.jpg?w=324&h=217
  3. At this point, try placing the battery back in the camera (if you have removed it), turn the camera to one of the capture modes, and press the power button. If all went well, your lens should now be able to extend and retract properly.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Camara turns on beeps shuts off
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Dec 23, 2007 | Canon PowerShot A520 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Canon PowerShot A520 Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
