Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ... so, i picked up a new board and changed it out. still wouldn't run.
  • 236 Answers
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Posted on Nov 12, 2009
Won't Fill
Hello Ben - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink)
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Verify the inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Confirm that the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some dishwashers use a water pressure switch that will shut off the water valve if the tub over fills.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jul 16, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher Mod 587.14419400 no power to fill valve
Check the float (make sure it's free to move up and down) and check the float switch.
Jul 25, 2012 | Kenmore Dishwashers
We went to run our dishwasher and lights are out....nothing works......house fuse fine. Been told to look for fuse box inside of dishwasher panel but cannot identify.
if the circuit breaker is good then you need to check the main power line to the unit and make sure everything is connected properly.
Oct 24, 2010 | KitchenAid Dishwashers
Dw stopped in midcycle.
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
May 31, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore dishwasher 16019 will not power on
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
May 29, 2008 | Kenmore 24 in. 16019 Built-in Dishwasher
Kenmore 16604
No reset button. Most likely, the thermal fuse went out. This happens if the water inside gets too hot. The thermal fuse is clipped to the electronic board behind the console. The heater thermostat is underneath the tub on the right side. The parts should cost about $25.00 total.
OR: the connection inside the connection box melted itself apart (installation error.) This happens, but not very often. Turn off the breaker. Remove the toe panel and the cover over the terminal box. Physically inspect the connections. You'll know immediately if this is the problem.
Mar 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
143 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
