Question about Whirlpool Inglis IP4400 Washer
Washer fills but drains at same time - Whirlpool Inglis IP4400 Washer
  • Whirlpool Master
  • 43,501 Answers
Chgeck that you drain hose rises above the water level before going into the drain. If not then the water will siphon out as you put it in. The drain hose must go UP above the top of the washer and then DOWN into the drain.
Posted on Nov 12, 2009
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
Fills and Drain...
Check your washer drain line for a possible siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link I provided. Your problem may be a simple matter of drain hose placement. If this does not solve your problem, please post back and let me know. I hope this helps you.
Jun 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leak
I WISH I COULD HELP YA. LET ME TAKE A SHOT AT THIS: IT SOUNDS LIKE A HOSE IS LEAKING ON YOUR WASHER. HOW OLD IS YOUR WASHER?
RODNEY
May 14, 2009 | Kenmore Washing Machines
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washer continuously filling/emptying
Your drain hose from the washer is in your household drain line too far, should not be any further in the drain line than 7 inches
Mar 23, 2009 | Washing Machines
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer both fills and drains at the same time
if your unit is both filling and draining this is usually from a siphoning action, caused by improper drain lines, you should drain the unit into a standpipe at lleast 36inches from floor, and have an "air gap" so as to prevent "siphoning"
Jan 10, 2009 | Washing Machines
Maytag top load washer pavt244aww leaking into drain
Chad -- Your problem most likely is the drain hose is either
a) Clamped tight to a drain line of some sort allowing water to siphon out
b) Washer drain hose is Shoved too far down the drain pipe
c) Drain pipe is lower than tub of washer alllowing water to drain
Oct 18, 2007 | Washing Machines
Whirlpool Inglis IP4400 Washer Logo
149 people viewed this question
Dan Webster
Dan Webster
Sal De
