Question about Audiovox Video Cameras
WHAT IS THE AC ADAPTER MODEL A2122ON FOR?
I FOUND THIS ADAPTER AND DON'T KNOW WHAT IT'S FOR. WHAT IS THE AC ADAPTER MODEL A2122ON FOR?
Dont know what make of lead i needadaptor and power lead for elonex windows xp which do i need
Margaret,
Need more info.
Right now you are in the Laptop PC category.
It looks as though you may need info for a Desktop PC.
After you post more info, we will get this straightened out.
Post the computer manufacturer name, and model number.
The model number for a desktop computer, can be found on the back of the computer; near the Windows product key.
Or up on the side of the computer tower.
The model number can be found on the Bottom of a laptop.
Please post back in a Comment.
WHAT a minute! Click!
Elonex laptop computer?
USA dude here, and I almost missed that.
OK, now I need the model number.
Also wish more reference to what power lead you are referring to, and what adapter?
AC adapter (Charger)?
Plug adapter for the power cord on AC adapter?
May I ask what country you are in?
Regards,
joecoolvette
Mar 14, 2013 | Computers & Internet
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
Where can i buy a ac adapter - model js-12060-3k for a packard bell tv?
Here some sites I found using Yahoo. Please make SURE that the output voltage & amperage from the new adapter is correct for your model. It should be on the back of the TV by the model & serial # or where the adapter plugs in. If you have the original to consult, that's your best bet. I hope this helps & good luck!
http://www.powerpayless.com/12v-6a-jewel-js-12060-3k-ac-dc-power-adapter-equiv.html
http://www.pchub.com/uph/laptop/345-42623-12247/Jewel-JS-12060-3K-AC-Power-Adapter-5V-12V.html
http://www.lcdpayless.com/productpage.php?productId=1963
Jul 06, 2012 | Computers & Internet
Where can I find an ac adapter for this monitor
You have not mentioned the make/model of the monitor. However there are several universal types and all what is required is to correct the connection pins and the polarity once the voltage are known which can be found in universal types.
Dec 17, 2011 | Fuji FP-768 17" Flat Panel LCD Monitor
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
We have an Acculab V-200 electronic balance here at school. The AC adapter was misplaced, however one with a 12 volt output was found. It fits the balance but I am afraid to plug it in since the unit can...
re: Acculab V-200 Digital Scale
The original AC acpater is rated at 12VDC 300mA output. It is unregulated (i.e. the output voltage is about 16-17V with no load)
The centre pin is NEGATIVE, which is the opposite of "most" AC adapters.
(Acculab model number is 41-12-300D, for the 120V 60Hz version)
Aug 16, 2011 | Health & Beauty
GOOD DAY, the AC adapter model EXA0801XA DON`T CHARGE MY NOTEBOOK ASUS. ANY TIMES WHEN THE AC ADAPTER IS PLUG, TURN ON THE LIGHT BLUE, BUT AFTER 2 SECONDS (APROX) THE LIGHT OFF AND NEVER CHARGE MY...
Here are some steps you could take to try and solve the problem
  • Make sure all parts of the adapter are plugged tightly together.
  • Try plugging the adapter into a different wall socket.
  • Try the adapter with another computer to make sure that your laptop is not the actual problem.
If the adapter continues to fail after all previous steps are taken you may just need to buy a new adapter. Not to worry though as brand new adapters can be found for next to nothing on websites like Amazon.com or Ebay.com
Jun 12, 2011 | Aftermarket Group ADP-36EH AC Adapter...
I need to know the AC/CD adapter part number for the Vector 450 AMP Jump Start System so that I can get the correct one from CNAweb.com
5140045-42 AC Charger with Small Jack 12v 500ma 2.5*5.5mm. For units Manufactured with date codes before October 2006.
Aug 05, 2009 | JUMP START SYSTEM
Not starting
Sounds like the battery died. This may have happened because the AC Adapter was not properly charging the battery. To see if a faulty AC adapter is the cause, check the following: 1) Is the indicator light on the AC adapter on? Most AC Adaptors have one. 2) Is the indicator light on the laptop on notifying that the battery is charging while plugged into the AC adapter? Try to borrow an AC Adapter from some one who has the same model laptop that you have. It is VERY IMPORTANT to get an AC Adapter with the same voltage and amperage ratings as your current AC Adapter. If not, yo urun the risk of damaging the electronics. If you do not have a spare, there are sever web sites that sell AC Adapters. http://store.comptick.com/brands-abit.html http://www.laptoptravel.com//AdapterSelector.aspx These appear to be the requirements of the AC Adapter. Double check these with what appears on the AC Adapter. Input: 110-240V 50/60Hz Auto-Detect International Compatible Output: 19V - 20V DC, up to 90W max If you are unable to find what you are looking for on the sites above, you can readily find what you want on ebay as well.
Oct 12, 2006 | Acer Aspire 5670 Notebook
Video Cameras Logo
41 people viewed this question
Top Audiovox Video Cameras Experts
NOEL
NOEL
Tony Parsons
Tony Parsons
Are you an Audiovox Video Camera Expert? Answer questions, earn points and help others
