Question about Lexmark X1150 All-In-One InkJet Printer
I just turned my Lexmark x1150 printer on or tried to only to find out the lights didn't come on. It has new ink cartridges in it, could it be the adapter? I recently moved so the printer hadn't been used in two months thus not even plugged in. Any suggestions?
    Problem Solver:
  • 14 Answers
The best solution is to send the product back to the manufacturer for repair or replacement. If you have a receipt for the product and its within the warranty period (1 year) they will do this free of charge. I can help you with the process.
Muzu
Posted on Nov 12, 2009
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
When I try to print from my Lexmark X1150 it says that the wrong ink cartridges are installed but I am using Lexmark 27 and Lexmark 17 - I thought these were the correct ones - can you advise...
The 17 and 27 cartridges are compatible with your Lexmark X1150 printer. Try to manually wipe the cartridge nozzles with a soft moistened cloth. This will help clean the nozzles from dirts and clogs. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert one cartridge first. Close the cover. If no error, open the cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark X1150 All-In-One InkJet Printer
What are the steps to cleaning the print heads on the X1150 printer? New at this. Mike
On your computer, open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center) > From the Maintenance tab, click Clean to fix horizontal streaks > Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
Source: How to Resolve a Blurry Print Issue Without Replacing the Cartridge
May 07, 2011 | Lexmark X1150 All-In-One InkJet Printer
I just changed my cartridges for my lexmark x1150 and my blues are now showing pink.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Changing ink cartridges
Make sure the printer is ON.
Open the top of the printer.
The cartridges are inside the cartridge carrier. You need to squeeze the tabs on the carrier which will flip up the lids to reveal the ink cartridges.
For reference, here are links to the setup sheet and the user guide. The setup sheet has pictures that should help.
X1150 Setup Guide
X1150 User Guide
Nov 17, 2008 | Lexmark X1150 All-In-One InkJet Printer
Leaking Ink Jet Cartridge.Clogged Up My X1150 Printer
No Solution Found.Get Lexmark Customer Services To E Mail Me Or I Take It Back To Trading Standards. C>Craske
Oct 07, 2008 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
