Question about Mr. Heater Portable Kerosene Heater - 50,000 BTU
Heater runs for a few minutes then shuts down need trouble shooting guide. owners manual no help
Need a manul
Posted on Nov 12, 2009
Changing thermostat on ruud water heater
1) Copy following link to adjust water heater temperature.:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add a comment if more help is needed. Jan 2013
Jan 26, 2013 | Rheem Ruud Commercial Electric Water...
My 85000 is older and has a gas sensor and copper tube conneced to the main gas valve. the problem is the same when I let off the start button the fire stops, some times it will operate for several minutes...
Is the fan coming on when you press the start button? If not, that's the problem. Or it may be inadequate gas pressure. These are just 2 of the most common issues. So, I have included a link to your Owners Manual, that you can download and print for future reference. Please pay close attention to the Trouble Shooting Guide part of the Owners Manual.
http://www.desatech.com/manuals/Construction%20Heaters/113893-01.pdf
Really hope this helps solve your problem. Please let me know.
Mar 09, 2011 | All-Pro SPC-85 Utility Heater
I have an allpro 115000 btu torpedo heater. Igniter works, nozzle flows freely and the heater runs on jet a. Never had a problem, now ignition is intermittent, heater shuts off within 10 seconds and does...
According to the Owners Manual Trouble Shooting Guide (Page 8), there are 9 different things that could be causing the problem you have. Fortunately, there are 9 solutions to finding and fixing the problem.
Below is a link to your Owners Manual (in case you have misplaced yours) that you can download and print for now and future reference.
http://www.desatech.com/manuals/Construction%20Heaters/113282-01.pdf
This should get your heater fired back up.
Mar 07, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My kerosene heater will try to turn on but neverfire up what could it be
There are 9 things that could be wrong, as well as 9 solutions to solve each particular problem.
Here is a link to your Owners Manual that you can download and print for future reference. Pay particular attention to the Trouble Shooting Guide on page # 7.
http://www.desatech.com/manuals/Construction%20Heaters/108871-01.pdf
This should get you back up and running.
Mar 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
The heater shut off after it ran out of fuel ---- after refueling and plugging unit in the heater won't start--
There are a couple of things tat could cause this. The first that pops into mind is that since the tank ran dry, it may be a fuel pressure problem. However, since you didn't mention if didn't work when you turned the ON/OFF switch ON, it's hard to know.
Also, since it ran dry, the fuel filter may be clogged. Since it may have sucked up some slug from the bottom of the tank.
In any event, her is a link to the Owners Manual for your heater, as well as a Trouble Shooting Guide, that should aid you in making any necessary adjustments or repairs. If you like, you can print the manual for future reference.
Hope this helps to get the heater backup and running.
Feb 24, 2011 | Desa International ReddyHeater R70ET...
I have a reddy heater multi fuel 115000btu. Worked great for 8 years with a little use every winter. Never done anything to it. One day it shut off with the thermostat satisfied. I let room temp go down...
You've done all the right things so far. I would recommend the you go to the following link. Look up your model number and download the Owners Manual and consult the Trouble Shooting Guide. But, I suspect, it may be bad fuel. None the less, consult the Owners Manual.
www,desatech.com
Hope this helps you solve the mystery.
Feb 15, 2011 | Heating & Cooling
We had a Hayward pool heater (300,000 BTU) with electronic ignition installed just under a year ago. Lately, it displays the IF warning, meaning ignition failure. But the burners do light up for a few...
Use the Hayward website to search for service providers in your area. If the heater is still under warranty you are b4est served to let a Hayward rep come out and fix it at no charge to you.
http://www.haywardnet.com/locator/
Be sure to select repair under the purpose for your search.
Aug 04, 2009 | Hayward H Series
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
541 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
