Question about Palm Tungsten T2 Handheld
Iam desprately trying to get my handhald computer on to a bllitz wireless modem but it will not connect because Idon't have a dns address
  • Palm Expert
  • 346 Answers
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Normal 0 http://kb.palm.com/wps/portal/kb/na/tungsten/t2/unlocked/supportservices/page_en.html
Posted on Nov 19, 2009
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
example:
IP address: 192.168.1.13
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
note: 192.168.1.1, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
Connecting internet to wireless router
If you are trying to connect your wireless router to your ADSL modem then ( ADSL Modem -->Wireless Router-->Your Computer) dont enter any values in the ISP, DNS and MAC address fields. Let them be on default as :
Domain Name Server (DNS) Address Get Automatically From ISP
Router MAC Address Use Default Address This would then automatically pick up the settings from your modem.
You should remember to ad a WEP key to secure your wireless.
Apr 11, 2010 | NetGear WGR614 Wireless Router
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
May 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Router will not connect to internet
You will need to assign a different ip address to the modem - Iam assuming that both the router & modem are using the same ipaddress 192.168.1.1? If that is the case, then assign 192.168.1.2 tothe modem.
Mar 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router connections
hi auxil first of all if your getting the interenet when your router is connected with the cable the modem and router are mostly set, if your not getting it with the wireless then it may be a couple things:
1. is your router set up as dhcp so it hands out the address to the computer trying to connect, this is normally a range of addresses starting with 162.168.X.X where x is the range.
or it can me 10.0.0.X. depending on your modem and how it is set up.
2. once it's a dhcp the computer your are on be it a desktop with a wireless card or a laptop with with a wireless connection needs to be set up to accept the dhcp, most computer and opterating systems do this for you, but if you have changed your ip to a static ip it needs to be in the on the same network as the router.
so this in mind the easiest way is to let the router give the connecting computers their ip, so to check this go to your connections, then right click on the wireless connection......choose properties......then choose tcp/ip and properties button.....then make sure it has the obtain ip address automatically and the same with the dns then click ok to all the boxes closing them.
3. if this still doesn't cconnect you may not have set up the dns and default gateway in the router,
to get this information when your wired in the router, and it's working, on wondows click start then go to run, type cmd and hit enter, when the black box appears type ipconfig /all (note:make sure there is space between config and the /all)
look the for the lan network and look for the dns primary and sec these are the address for your routers dns, and check the default gateway this should be the modems address.
with these in your router you should be able to connect.
if not get back to me, hope this helps.
Oct 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless router problems
your computer is only connected to the signal coming from the router that's why it's saying connected but it seems that your router is not properly configured to provide internet access since your dns server is the same as your default gaetway. it could be that the your router is not in sync with the modem.
- if it's working before, tyr to power cycle everything by turning all the devices off then turn on the modem first, wait for all the lights on the modem to turn on then power on the router and the computer.
- if the router is for initial setup, kindly provide me you ISP, brand and model of the modem and how you connect the modem to the router and tell me if how you access the internet directly from the modem.
Jul 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network...
please help me iam wired connection to the playstation 3 i have ((dns error)) but i still can make any download please help me quikly ......
engineer.sabah .talal
Apr 01, 2008 | Sony Playstation 3 (PS3) Console
Laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
Jan 17, 2008 | Computers & Internet
Palm Tungsten T2 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
