Question about Palm Tungsten E2 Handheld
I just recently realized that I have a plug in charger assembly that i have never used. when my battery shows low i simply connect my palm Tungsten E2 to my lap top computer with the USB cord and it recharges. What is the purpose of the extra charger? thank you.
  • grahamp1 Nov 12, 2009
    Solution was very helpful and confirmed what I thought was the answer, but wasnt sure.
  • 8,197 Answers
The plug in charger is if you are at home you can plug the phone with charger in your wall outlet and charge it that way. You do not have to use the lap top to charge the phone.
Good Luck
Posted on Nov 12, 2009
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
It will not turn on. It is 3 yrs old.
If it is not turning on at all then more then likely the battery is dead. Try plugging it into the charger and leaving it for over night. Then try turning it on. If that doesn't work you may need a new battery. I would not recommend doing this yourself s it involves some soldering. I had a friend of mine change my battery and it didn't quite work right after that. I am also including a link for the free chat feature that palm has. I have used it several times and have always had very good results. Best wishes.
At the bottom of this page it says Palm Chat. Click on the chat now and follow the online prompts.
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/supportservices/page_en.html
Nov 19, 2009 | Palm Tungsten E Handheld
New battery in my 2+ year old E2.
its a good possibility that you could have received a bad battery or maybe even over charged the device. I would consider returning the battery for another and if problem still exist you should consult Palm about the nature of your problem
Nov 16, 2009 | Palm Tungsten E2 Handheld
My Tungsten E2 is not charging. It has been with me for almost 4 years now. What seems to be the problem? This is not the first time though I encountered the same problem. 3 years ago I encountered the...
I had symptoms with my Tungsten E2 where the charging icon would show up when the charger was connected, however, it didn't seem to charge, because when it was removed from the charger hours later, it would still show the same percentage of charge (as read by touching the battery icon while in the favorites screen).
Tried resetting the unit, reconnecting multiple times, different charge cables, and it was always the same.
I thought it might be time for a new battery, so to check it out, I got my T-5 Torx driver, removed the four case screws, and carefully pried open the case from the top (the bottom has hooks that have to be disengaged by sliding the case half downwards after they're separated from the top)
Measured the battery and it seemed to be okay, and after unplugging the battery connector and reconnecting it, it worked normally again. Charged quickly back up to 100%, and the battery is fine.
It looks like something may get out of sync with the battery charge circuit, and by simply unplugging the battery to allow it to reset, it restored operation, no replacement battery needed.
Sep 27, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2 won't power up
Please follow the steps to isolate the problem:
1. Make sure that the charger is working.
2. Try using different charger just to make sure.
3. Try using different battery.
If the phone works using different battery, you need to replace your old battery, but if not, this phone needs repair.
Apr 17, 2009 | Palm Tungsten E2 Handheld
Will not turn on
It's possible that the battery can no longer hold a charge anymore.
Check with Palm to see if there is a replacement available.
It should work if you have a car charger on it while using it.
Mar 31, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Will not fully charge
its possible its losing the connection overnight, which could mean its something with the charger port in your phone. Have you tried other batteries or chargers with the device
Nov 18, 2008 | Palm Tungsten E2 Handheld
Replacing battery in Tungsten E2
Sounds like the battery you got is bad. You should get it replaced.
Jun 23, 2008 | Palm Tungsten E2 Handheld
Tungsten E
Hi : This means your battery must be as dead can be. Therefore it seems to be getting straight power only when you plug in the charger. Or your on/off button is dead. Are you able to turn it off/on when you have charge plugged. If so then I suggest getting a new battery for the E2 Palm and you should be back up and running. If this is not the case then it is your on/off button in which it could be just the contact or the switch itself. I can suggest someone in US if you like, else I can handle it but I am in AUS.
Oct 02, 2007 | Palm Tungsten E Handheld
Palm Tungsten E2 Handheld Logo
22 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
