Question about Mtd Heavy Machinery
Tecumseh chipper shredder-vacuum After two years cleaned carb. No spark What do I do next?
  • 486 Answers
How have you determined that there is no spark? Have you used a type of spark tester?
What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
If you do not have a spark tester, remove the plug, and with it connected to the wire,
find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
That age of unit should have electronic ignition, so if there is a 'no spark' condition, I would double check safety switches that are found on snouts, shrouds, bags, discharge chute, ect.
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 12, 2009
Testimonial: "Thank you. I will check these mentioned location for saftey switches. Don Ellis 1-901-854-5556"
My troy built chipper shredder vacuum wont start. It has fresh gas, checked the spark plug and blew out the air filter. Any ideas?
If you have left it standing since last season without draining the old gas then its likely there is old gas residue left as a white crud in the carb. This has blocked one or both jets. If you undo the float bowl and its inside then get the carb cleaned out. You will need an airline.
Nov 04, 2014 | Heavy Machinery
Engine will not fire or try to start on my Troy-Bilt Super Tomahawk 2 in 1 Chipper/Shredder, 8 h.p., Tecumseh engine. Getting good spark; changed to new gas; no air blockages found.
If your getting spark no doubt its a fuel problem. Does the inside of the cylinder look wet when you removed the plug. The seals in carb go bad all the time. You need a rebuild kit most likely. Very cheap an easy to do. If its a bowl carb it should be done. Should solve your problem. Starting problems are no spark or no fuel. Carb leak an seal get weaker all the time. Gas the way its made today eats the seals away.
Mar 05, 2014 | Troy-Bilt Heavy Machinery
Need spark plug type and gap setting Craftsman 247.775870
Champion N4C, Gap: .030
Air filter: tecumseh 36046
Pre-filter: Tecumseh 36634
Jun 20, 2013 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a Troy-Built Chipper/Vac Model 47279 (5HP) that has not been run in a while. I have drained the fuel and added new but it will not start. The old fuel did not have any fuel additive prior to storage...
i have the same Chipper, vac. Have you checked for spark? You may want to clean the fly wheel. I use emery cloth to clean the area at the magneto, If there is no spark, Also you may have to clean the carb. I have been looking for a manual for this model with no luck. Hope this helps!
Jul 30, 2011 | Troy-Bilt 24" SelfPropelled Chipper...
I have a Tecumseh 4.5 2 cycle engine on my snow
fuel filter thats were i would check fuel will turn gummy in the filter if it sets
Feb 10, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
24a-020d700 won't start, new gas & replaced air filter
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
Jan 02, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Heavy Machinery Logo
171 people viewed this question
Top Mtd Heavy Machinery Experts
rjivaro
Roland W VanLue
Roland W VanLue
obsteiner
Are you a Mtd Heavy Machinery Expert? Answer questions, earn points and help others
