Question about Creda W120VW Front Load Washer
Fit a new door hinge
Anyone able to advise me on how to fit a new door hinge please?
  • Creda Master
  • 3,463 Answers
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
Change side of door opening
Remove the door by unscrewing the top hinge and lifting off. Remove bottom hinge. Using what was top hinge, fit to bottom of opposite side. Fit door on with "top" hinge and secure.
Apr 26, 2012 | Refrigerators
How do you fit an oven door to a Hotpoint BD81P oven? My hinges need replacing ?
Go to
WWW.YOUTUBE.CO.UK
In the search box enter---FITTING OVEN DOOR HINGES
You will find some very informative videos on how to fit the hinges.
Dec 04, 2010 | Hotpoint Ovens
Best way to fit saloon door hinges . how to set out the job before fitting saloon door hinges
Set the bottom height first and make sure the two are level ... then fit the door ... allow for the up and down movement required by the bottom hinge.
Mar 24, 2010 | Drills
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
Hi,i have fitted rising **** hinges but i think they are not quite right , the door will not rise as it should thank you
Too bad that the censor on this website won't allow the word "but" with the second "t"!  Assuming that you've really got "rising ****", and not plain "lift-off" hinges, you've probably got hinges with the wrong "handedness".  Rising **** hinges come in left- and right- handed versions (for left- and right- hinged doors): fit the wrong one and the door won't rise! Whichever hand you've got, try fitting the other hand and your problem should be solved.
Good luck! If this has been helpful, please remember to rate my response.
Oct 08, 2009 | Stanley Hand Tools
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
The machine door is hanging off the hinges xx do i need a new door or hinges
More than likely, all you need to do is replace the door hinge., you will probably have to seperate the inner door panel from the outer panel to fit new hinge.
Thanks.
Sep 09, 2009 | Hoover Washing Machines
BOSCH SGS6302GB
Hi nikkij
It is simple to put them back on. the plastic pices fit on the bottom of the hinges. there is a cut out where they fit in. when you look at the door at the bottom you will see the hinges and the cut outs, the plastic pices fit in the cut outs flat side in. hope this helps
Sep 15, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Jul 01, 2007 | Zanussi ZBQ365 Electric Single Oven
Creda W120VW Front Load Washer Logo
498 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
