Question about Apple iPhone Smartphone
Ringer volume is stuck on screen - Apple iPhone Smartphone
  • 502 Answers
Sorry but your silent switch needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself. The part is on Ebay.
Posted on Jul 10, 2010
HOW DO INCREASE RINGER SOUND
Hi Melvin
Majority of phones... when you are in the PHONE screen , just
Press the "+" button on the upper left side of the Phone. The Ringer screen will appear, superimposed on top of the screen you most recently used. Click the "+" button one time to raise the volume one level. Continue clicking the "+" button to raise the ringer volume higher until its at the maximum level...or however loud you want it.
Apr 28, 2016 | Cell Phones
How to Ringer On of Panasonic KX-MB772
Before adjusting volume, set the operation mode to fax
mode (page 16).
Ringer volume
While the unit is idle, press {V} or {^}.
L If there are any documents in the document
entrance, you cannot adjust the volume. Confirm that
there are no documents in the entrance.
To turn the ringer OFF
Press {V} repeatedly to display "RINGER OFF= OK?".
i {SET}
L The unit will not ring.
L To turn the ringer back ON, press {^}.
Ringer pattern
L You can select one of 3 ringer patterns (feature #161
on page 50).
Monitor volume
While using the monitor, press {V} or {^}.
and if it work then say a thanks to your Pakistani Brother.
Dec 10, 2013 | Panasonic Office Equipment & Supplies
Don't know how to increase the ring volume?
To increase the volume for the ringer, the volume buttons located on the charging stand can adjust the volume. To change the ringer volume on the phone instead of using the stand, go to the menu on the phone and type 1 then 1 again. This will take you to the ringer volume screen. You can select between the options:{1}: Low {2}: Medium {3}: {0}: Off.
May 06, 2011 | Panasonic KX-TG5632 Phone
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you turn up the ringer volume on the Jitterbug phone. It's currently set on vibrate & I don't know how the volume got turned that far down.
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Jan 31, 2011 | One Touch Jitterbug One-Touch Cellular...
The telephone is on vibrate. How do I return it to ringer?
If you need additional help, you can call a customer service expert available 24 hours a day, 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Dec 05, 2010 | One Touch Jitterbug One-Touch Cellular...
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Apple iPhone Smartphone Logo
1,236 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
