Question about Dell W3202MH 32 in. LCD Television
Dell W3202MH LCD monitor gets power, but no image. Backlight?Power indicator light comes on, but no Dell logo or anything on the screen.
  • shortjt Nov 17, 2009
    Thanks for the quick response and suggestions. We've used another working W3202MH to narrow it down to the main or larger control board that the video inputs are connected to. I'm not quite sure how to narrow it down to a particular component on this board, however. Do you know any sources on parts or where we can find a refurbished board?
    Thanks!
We have this exact same problem. Did you ever figure out what it was?
Posted on Dec 14, 2009
  • 11,361 Answers
It can be bad backlight inverter board or bad power supply for the inverter. Look at the power supply first since it is easy to get too than the inverter board, look for bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. Pictures will help.
Posted on Nov 12, 2009
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
When i power up there is just a lightened black screen, no loading screen of anything
check RAM, or take out the battery for some times then insert it again then check, if this does not solve the problem then check the display to a monitor through a vga port, if there is no display then its the fault of mother board take it to the service centre
Sep 12, 2009 | Dell Inspiron 1420 Notebook
Need help for my Dell Inspiron 9400 Laptop
Try and determine what is wrong with your LCD screen first and you can then decide the best course of action. Follow these instructions to determine the fault and then check out LCD Parts WEB site for parts, replacement LCDs, service and DIY info..
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 03, 2009 | Computers & Internet
Dell Inspiron 6400 - Screen visibility problems
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Dell Inspiron 6400 Notebook
Screen takes several power up attempts to fire up
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 18, 2009 | Dell Latitude C840 Notebook
Laptop screen Problem
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Picture flickering with dim display.
Apr 11, 2009 | Dell Latitude D810 PC Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Dell Precision M60 Notebook
Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Dell Inspiron 6000 Notebook
Power light comes on but screen will knot light up
shine a torch onto the screen when it is running. if you can see the images then your backlight has gone and you need to replace.
Feb 26, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Televison & Video Logo
567 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
