Question about RIM BlackBerry ® 8830 Cellular Phone
My computer immediately shuts down when I plug my World Addition in to hotsink. Any way to troubleshoot?
  • ecsdayton May 11, 2010
    Do you have an SSD card in it? If so can you remove it can attempt again? can you let me know what OS your computer is running and maybe the make and model? If it is homemade, do you know what the motherboard is?
Pilot light is to high and all burner are red but the center and it burnes blue on a list world knw321 what could be problem and how do I adjust the pilot light it is to high
You've got a red flame then you need to shut down the unit IMMEDIATELY!!!!! This due to incomplete combustion and could be due to a lack of fresh oxygen entering into the unit, or the units exhaust is block somewhere in the line. Shut it down now and call an expert!!!!! Gas Flames Yellow vs Blue Gas Flame Colour Temperature
Jan 22, 2017 | World Heating & Cooling
I just got my logitech N700. Every time I try to plug the usb cable into my computer, however, my computer shuts down. I tried injecting other things - my flash drive, my external hardrive, and my old fan...
Try shutting down your computer before you plug in your USB. As you may have a surge problem. Then plug in your N700, if this doesnt work You may have to goto PC world or your local PC dealer and ask them. Hope this helps.
Feb 27, 2011 | Logitech N700
Computer shuts down immediately after I turn it on.
First look for the obvious-make sure it's plugged in to a power source and make sure you got enough battery power. Nothing?
It immediately shuts down, because it's telling you it needs to be taken in to have the Apple dorks fix it, as this is not something that can easily be fixed on a web site. Opening this thing up with hands on fixing is required for your machine, but keep in mind that your warranty is void if you spilled water on the laptop.
Nov 02, 2010 | Apple MacBook Mac Notebook
Audi S4 radio turns back on after you shut car off. In addition, the controls for the radio for the most part won't work, and you can't "Power off" the radio. It won't shut down, when you hit the power...
Some cars have new system in the computer that lets the radio function for 20 minutes after the key is turned off and no doors have been opened, system should shut down immediately after you open a door
Oct 06, 2010 | 2004 Audi S4
Added memory causes machine to shut down and boot up continually.
it proves that your emacchine does not support your addition of memory try a bit lower capacity memory
Aug 22, 2009 | Computers & Internet
I have a mmp8567 and it is giving me Boot Error Shutting down
My MMP8567 screen read ''boot error shutting down''.
Update the firmware. Download directly from Memorex site, Support section.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver''
After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
Jan 06, 2009 | Memorex MMP8567 MP3 Player
Memorex mmp8567 boot error shutting down
Nov 30, 2008 | Memorex MMP8567 MP3 Player
When I push the ''on'' button with the computer plugged in, won't b
The battery is clipped at the bottom of the laptop, it sounds like the PSU circuit in your laptop has failed and you might want to consider taking it to a computer shop, but get quotes first as some shops still act like cowboys.
Nov 20, 2008 | Aspire Acer 53152826 Notebook
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
RIM BlackBerry ® 8830 Cellular Phone Logo
22 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
