Question about Polaroid FLM-4201 42 in. LCD Television
My screen will go black after a few minutes of run time, I flipped it over and the 613 light inside it is lit up any ideas?
  • 11,361 Answers
If you have have any indicator lights on, then at least he 5v standby circuit is still workin. The problem can be in the backlight inverter board or the power supply for the inverter board is bad. Look at the power supply module first since it is easy to get to for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 12, 2009
My flip video won't turn off or record, won't be acknowledged by PC via USB port - seems to have frozen - screen is black but light behind it showing power is on but can't do anything with it.
To fix, I held the on/off button down for an extended time (around 10 secs approx) until it finally turned off. Left it alone for a few minutes and then turned back on. Worked okay. Also got a response from flipshare support who said there is a reset button inside the tripod space, use a pin to press that and then fully recharge camera via USB slot on PC.
Jan 12, 2010 | Pure Digital Flip Video Ultra Camcorder
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
BLACK SCREEN
try reseating the memory. in the process use a pencil eraser to clean contacts and see if it works.
Is their a possibility of an overheat with your laptop? i mean, during the time that the laptop froze up, did you notice that the laptop is exceptionally hot?
Apr 09, 2008 | Sony VAIO VGN-FS640W Notebook
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Blank or black screen
there is a problem with the flex..might be damaged..have it replaced by a cellphone technician
Jan 01, 2008 | Motorola Mobility i880 Cellular Phone
Starts up but turns onto standby straight away
There could be a problem with the flip down iris protector. If the Sanyo is on and you flip the protector down manually then the projector will go into standby mode. This is obviously to protect the system incase it ever gets flipped down accidently and the system is on. There could be a faulty switcher inside the protector mechanism which is not working properly and the machine thinks that the screen is down when in fact it is open!
Switch off the entire projector at the mains and open and close the screen a few time manually. If you feel comfortable doing so try and force the screen up a little bit past its stopping point when it is supposed to be fully open. Be careful and don't break it. Now keeping it open plug it back in a see if that works and don't touch the protector ever again! If it doesn't try opening and closing a few more times to try and release the triggering button that is inside the projector screen.
I had the same problem and that worked for me.
Sep 27, 2007 | Sanyo PLV-Z2 Multimedia Projector
Blank Screens
try reflash the phone or replacing the lcd
Sep 12, 2007 | Motorola Mobility RAZR V3
Tomtom 910 will not power up
In a back of your GPS there is a small whole. You have to press with toothsstick to reset it.
Aug 20, 2007 | Tomtom GO 910 GPS Receiver
Polaroid FLM-4201 42 in. LCD Television Logo
118 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
