Question about Cameras
My hp photosmart m627 digital camera will not display images after a shot,also images will not store to memory card but internal memory after formating
  • 17 Answers
SOURCE: Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
Posted on Nov 11, 2007
  • 203 Answers
SOURCE: Image Storage
kodak has a internal copy feature in the menus-go through menus and find copy-may be only in playback menu mode
Posted on May 21, 2008
SOURCE: hp photosmart m627
We had the same issue - audio but no video on playback on a Win XP pc on both Windows Media Player and Media Player Classic. At some stage it suddenly stopped working - I suspect a Windows update?
I've found video plays back correctly with the VLC player: http://www.videolan.org/vlc/
I've raised a support call with HP regarding this issue.
Posted on Mar 31, 2009
  • 1162 Answers
SOURCE: I dropped my hp photosmart m627 and now it says
The only fix I kow of is to take the camera apart and set the gears on the lens correctly. You are going to need a small set of phillips and stright screw drivers, and a soldering iron.The back comes off easy enough, the next thing it to remove the screws on the back of the main board. the screws on the top function board. and then unsolder the two tabs on the top of the main board that connects to the battery compartment. Be sure to unsolder the correct ones. Once this comes off the camera lens is pretty easy to figure out. Just take the motor and gear section apart and set it correctly. I have done a few that when I just turned the barrell of the lens, I heard a snap and it worked fine. You may have to take it apart. If you need more help contact me at cwradio73 at gmail.com
Posted on Aug 04, 2009
SOURCE: Olympus E-300 Digital SLR storing black images.
Most likely the shutter "curtain" (a few pieces looking like sheet metal just behind the mirror, designed to protect the camera CCD from dust and damage due to too much light) is not opening. This will require servicing by Olympus, since you will have to take the camera apart to be able to reach this camera part. Unfortunately, this may be a pretty expensive repair.
Posted on Dec 09, 2009
I am trying to format a scandisc 8GB sdhc card for my HP m627 camera....but cannot ....can u help? Thanks Tim
The M627 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Aug 27, 2011 | HP PhotoSmart M627 Digital Camera
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
I bought a SanDisk 4 GB and my HP photosmart M627 will not format the memory card
The M627 works with SD cards. Your 4GB card is an SDHC card and will not work with this camera. You need to use SD cards, 2GB and smaller.
Jul 29, 2011 | HP PhotoSmart M627 Digital Camera
I cannot Format the memory card on my camera,HP photosmart M627. Can you help?
Try to get hold of a usb card reader that support your memory card and format it on your pc, both the camera and the card reader is using the FAT 32 File System to format. The one i use is a Transcend RDP8 and can take five different cards
Dec 11, 2010 | HP PhotoSmart M627 Digital Camera
My photosmart M627 have error lens 30 Help me! Sul display della mia photosmart appare la scritta error lens m627-30 che posso fare grazie!!
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 07, 2010 | HP PhotoSmart M627 Digital Camera
Hp photosmart m627
Jul 15, 2008 | HP PhotoSmart M627 Digital Camera
Unable to capture images
This is a failing component in the camera Contact HP customer support for a replacement or trade in
Sep 03, 2006 | HP Photosmart E317 Digital Camera
Memory cards
You may be able to store up to 110 images if you use the camera in its lowest resolution mode. In high resolution, you may get only 24 shots. We wish we could tell you precisely, but it depends on the exact size of the file created by a given camera, as well as the resolution that you select. Keep in mind that Secure Digital, CompactFlash, and SmartMedia memory cards are competing products and are not interchangeable. You'll find a few cameras that are compatible with more than one brand, but generally when you buy a digital camera today, you'll be making a commitment to work with one type of memory card. Use the attached chart to determine the average number of photos that Secure Digital memory cards can store (compatible with most HP digital cameras)
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
